post your Fuse/Relay/EMS panels
Old Jun 26, 2008 | 07:45 PM
RedneckRicer's Avatar
Default post your Fuse/Relay/EMS panels
starting on my wiring for my build and want to get some idea where to mount it and configure it. also what kind of sheetmetal are you all using to mount it on? are you mounting the board on bushings or mounting everything on bushings?
TIA
Old Jun 26, 2008 | 07:51 PM
redboost10's Avatar
Default Re: post your Fuse/Relay/EMS panels (RedneckRicer)
Thanks to Tony1 for the ems/ignition, clint at prs for the supplies, and kataku2k3 for the harness assembly
Modified by redboost10 at 9:01 PM 6/26/2008
Old Jun 26, 2008 | 07:52 PM
any bigger pix lol
Old Jun 27, 2008 | 12:41 AM
vectorsolid's Avatar
Default Re: post your Fuse/Relay/EMS panels (redboost10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redboost10 &raquo;</TD></TR><TR><TD CLASS="quote">
sweet!
Old Jun 27, 2008 | 11:00 AM
tony1's Avatar
Don't have any finished pics, but this was close.
Old Jun 27, 2008 | 11:52 AM
are you all using bushings on the plates or on the mounts for the Accessories?
Looks like you all are using Aluminum
Old Jun 27, 2008 | 12:51 PM
tony1's Avatar
Default Re: (RedneckRicer)
My plate is solid but the ignition box is mounted on rubber isolators and the ecu is mounted with velcro so neither will see much vibration.
Old Jun 27, 2008 | 01:56 PM
Justin Olson's Avatar
Default Re: (tony1)
Tony,
What relays and fuses are you using?
Justin
Old Jun 27, 2008 | 02:17 PM
Turbo-charged's Avatar
Default Re: (Justin Olson)
after you use one of those relay's you will never want to use any other type of relay ever again lol
Old Jun 27, 2008 | 02:25 PM
LA_HONDAS's Avatar
Default Re: (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">after you use one of those relay's you will never want to use any other type of relay ever again lol</TD></TR></TABLE>
do they come from prs
Old Jun 27, 2008 | 03:27 PM
Default Re: (LA_HONDAS)
I found this relay kit that looks like the right thing. Is this what I'm looking for?
http://www.casperselectronics...._Code=
Justin
Old Jun 27, 2008 | 03:45 PM
LA_HONDAS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Olson &raquo;</TD></TR><TR><TD CLASS="quote">I found this relay kit that looks like the right thing. Is this what I'm looking for?
Justin</TD></TR></TABLE>
dam i hate you
thanks for website now i can spend some more $$$$$$$$$$$$$$$$$$$$$$$$$$
Old Jun 27, 2008 | 05:03 PM
ALL IMPORT's Avatar
whats the plugs comming off the relays? im fixing to go through this. took the stock harness out the car & was amazed it weighted in at 19lbs.
Old Jun 27, 2008 | 05:14 PM
LA_HONDAS's Avatar
Default Re: (ALL IMPORT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL IMPORT &raquo;</TD></TR><TR><TD CLASS="quote"> whats the plugs comming off the relays? im fixing to go through this. took the stock harness out the car & was amazed it weighted in at 19lbs.
if you're talking about the thing on side of relay that's a fuse
you can get them from http://p-r-s.com
Old Jun 27, 2008 | 05:25 PM
Big Teggie's Avatar
Old picture when I was working on it, and its not baller, I will get a new one soon.
Old Jun 27, 2008 | 05:40 PM
pro-motion's Avatar
Default Re: post your Fuse/Relay/EMS panels (Big Teggie)
Really clean setups guys
Old Jun 27, 2008 | 05:54 PM
ninesecrx's Avatar
Default Re: post your Fuse/Relay/EMS panels (pro-motion)
Here is the setup for my car. I was sad when I saw the amount of dust on it
Modified by ninesecrx at 8:56 PM 6/28/2008
Old Jun 27, 2008 | 06:15 PM
rip94delsol's Avatar
Default Re: post your Fuse/Relay/EMS panels (ninesecrx)
ha, these are some sick setups
i have a question though. having the ignition box so far wont affect anything in the spark? say having the box in the engine bay compared to having it in the cabin wont make a difference?
Modified by rip94delsol at 9:22 PM 6/27/2008
Old Jun 27, 2008 | 06:18 PM
ninesecrx's Avatar
Default Re: post your Fuse/Relay/EMS panels (rip94delsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rip94delsol &raquo;</TD></TR><TR><TD CLASS="quote">ha, these are some sick setups
i have a question though. whving the ignition box so far wont affect anything in the spark? say having the box in the engine bay compared to having it in the cabin wont make a difference?</TD></TR></TABLE>
You need the coils next to the engine which is what makes the spark, not the ign. box itself.
Old Jun 27, 2008 | 08:24 PM
i understand that. say your using omc coils or msd blaster.
but what about using......nevermind. answered my own question
thanks
Old Jun 28, 2008 | 04:35 AM
tepid1's Avatar
Here is mine.... not 100% complete when I took the pics.
It's done now, but no updated pics....
Old Jun 28, 2008 | 05:29 AM
Default Re: post your Fuse/Relay/EMS panels (tepid1)
this almost looks like a post your motec panel thread haha
Old Jun 28, 2008 | 05:40 AM
ALL IMPORT's Avatar
Default Re: post your Fuse/Relay/EMS panels (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">this almost looks like a post your motec panel thread haha</TD></TR></TABLE>
motec ******
Old Jun 28, 2008 | 06:00 AM
red02s2k's Avatar
Default Re: post your Fuse/Relay/EMS panels (ALL IMPORT)
motec ******</TD></TR></TABLE>
Old Jun 28, 2008 | 06:11 AM
tepid1's Avatar
lol
Found another of it mounted in the floorboard via D-zus.
I'm out of pics now.
