post your Fuse/Relay/EMS panels
#51
Re: post your Fuse/Relay/EMS panels (tepid1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 »</TD></TR><TR><TD CLASS="quote">Here is mine.... not 100% complete when I took the pics.
It's done now, but no updated pics....
Seems I recall reading that carbon fiber/kevlar will transfer electricity.
#52
Re: post your Fuse/Relay/EMS panels (LA_HONDAS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LA_HONDAS »</TD></TR><TR><TD CLASS="quote">anybody know where i can buy obd1 ecu plugs and pins
I have a set of plugs with about 10 to 12 inches of wire on them.
#53
Re: post your Fuse/Relay/EMS panels (E.Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E.Honda »</TD></TR><TR><TD CLASS="quote">Seems I recall reading that carbon fiber/kevlar will transfer electricity.</TD></TR></TABLE>
Carbon most definetly conducts electricity, i've had switch panels short out because of it.
#54
Re: post your Fuse/Relay/EMS panels (Kevin)
im getting everything ready i think i got everything i need to start this wiring project. but i need to make sure that im not forgetting any accessories that i need to power
1. Headlights
2. Foglights
3. ECU
4. MW pro 10
5. Tail Lights
6. turn signals
7. gauges
8. Fuel Pump
9. Radio
10. Fan
would anyone else recommend another accessory?
1. Headlights
2. Foglights
3. ECU
4. MW pro 10
5. Tail Lights
6. turn signals
7. gauges
8. Fuel Pump
9. Radio
10. Fan
#55
Re: post your Fuse/Relay/EMS panels (RedneckRicer)
as you can see on my tray i have 3 relays/fuses, one is for ecu, the 2 others are for injector power. im not sure how many injectors you plan to run, but id put them on a seperate relay/fuse then the ecu(output side)
the switch can turn them all on at the same time.
#56
Re: post your Fuse/Relay/EMS panels (DaveF)
ahh thank you sir forgot about that.. I still need to order my FJO driver.. added it to my list.
#57
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedneckRicer »</TD></TR><TR><TD CLASS="quote">im getting everything ready i think i got everything i need to start this wiring project. but i need to make sure that im not forgetting any accessories that i need to power
1. Headlights
2. Foglights
3. ECU
4. MW pro 10
5. Tail Lights
6. turn signals
7. gauges
8. Fuel Pump
9. Radio
10. Fan
would anyone else recommend another accessory?</TD></TR></TABLE>
Horn, distributor, starter and license plate light.
1. Headlights
2. Foglights
3. ECU
4. MW pro 10
5. Tail Lights
6. turn signals
7. gauges
8. Fuel Pump
9. Radio
10. Fan
#58
So do the aluminum plates others are using.
Joe, looks like you need an ECU boot, eh?
Travis' mess of ****!
Modified by Kataku2K3 at 10:44 PM 7/1/2008
#59
Horn, distributor, starter and license plate light.</TD></TR></TABLE>
car has no horn... dont need any dizzy wiring since im running the MW pro 10 and crane coil( i thought big 12v line that went to the dizzy fed the ICM and the coil.
Car has a push start button so ground trigger is off that. Liscence plate lights are going to be ran off the rear parking lights.
#62
Car has a push start button so ground trigger is off that. </TD></TR></TABLE>
1st question, (blk/yel dist. power, yes it does power the icm and coil)
2nd thing- push start button, you need to apply 12v to the pigtail on the starter, or are you triggering a relay with the ground signal ?
#63
Doesn't matter if they're mounted to something conductive or not as long as you're not hooking the plate up to 12v. lol
#64
Re: post your Fuse/Relay/EMS panels (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">Doesn't matter if they're mounted to something conductive or not as long as you're not hooking the plate up to 12v. lol</TD></TR></TABLE>
That's what I was thinking
Also, who makes that relay setup on the the gold bar. I see that quite a few of you run it, and was wondering who made it, and where I could purchase it?
#66
I have a set of plugs with about 10 to 12 inches of wire on them.</TD></TR></TABLE>
i can get ecu pigtail plugs all day long for free
i wanted uncrimped obd1 plugs n pins
but thanks anyway
but thanks anyway
#68
Re: post your Fuse/Relay/EMS panels (boostedh22a)
Yeah, they're not on there. We have tons of stuff that isn't on the site yet. I don't have a dedicated web guy so slowly but surely on getting everything on there. You can call the shop if you need to order them or pm me for pricing.
#69
We have all of this stuff in stock, from tefzel wire in all sizes, rachem shrink in every size probably about 100ft of each size, autosports, deutsch connectors, transitions among other things. I am pretty sure a couple people around here have gotten things from Miller before.
If anyone needs anything please feel free to pm me and i will be able to get you pretty much anything you need.
#73
Re: post your Fuse/Relay/EMS panels (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 »</TD></TR><TR><TD CLASS="quote">
Modified by Kataku2K3 at 10:44 PM 7/1/2008</TD></TR></TABLE>
Thank you captain obvious.
It was meant to inform those who do not know.
#74
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF »</TD></TR><TR><TD CLASS="quote">
2nd thing- push start button, you need to apply 12v to the pigtail on the starter, or are you triggering a relay with the ground signal ? </TD></TR></TABLE>
I will have to run that power wire any ways for the coil.
the car is going to be Key less. so i will hook up the the starter signal wire to replace the Ground switch on the starter.
#75
Re: NRG, snakes again ! (DaveF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF »</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
is there a problem with what i said?
