Will LOW gearbox oil, cause HARD shifting
I have a problem guys.
I have a 00 Si.
b16a engine
The problem is that when i shift at 8200rpms, the gears are VERY hard to SELECT/Put In.
Any gear, 2/3/4.
At Low RPM, its not so hard to find the gears.
A mechanic told me, it is possible i have low gear oil.
What do you guys think
I have a 00 Si.
b16a engine
Any gear, 2/3/4.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">Try replacing the fluid with Honda MTF, and see if it improves. </TD></TR></TABLE>
Also how are your shifter bushings?
Are the motor mounts in good shape too ?
I use a suction gun to fill the tranny. You can buy one next to the grease guns at the auto parts store.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20beast83 »</TD></TR><TR><TD CLASS="quote">my linkage is BENT.
would that cause a problem?
Or, my motor is out, will the car still run?
Ya, that might cause a problem, lol.
My gearbox has new honda mtf, about 3 months old</TD></TR></TABLE>
a bent linkage didn't throw up a flag earlier than this?
3 month old mtf, but was it adequately filled? it doesn't matter how new it is if there isn't enough of it.
HavokB18
20
May 29, 2003 04:16 PM
