Muffler rattle
Old Jun 26, 2008 | 01:30 PM
ductmow's Avatar
Default Muffler rattle
I just bought a used catback and after i installed it, there is a rattling sound in the muffler. It sounds like theres rocks in there or something so i took off the muffler and shook the muffler to see whats inside. It feels as if theres alot of sand and a few rocks or something. Do u you guys know what i can do about this or did i just blow a couple bills on something broken
+It rattles the loudest around 1.5k rpm
update:found out the rattling sound is mainly coming from the exhaust itself rattling. Anyone have any suggestions how to clamp it down or something? I am using the old rubber hangers still.
Modified by ductmow at 2:41 PM 6/26/2008
Modified by ductmow at 5:17 PM 6/30/2008
Old Jun 26, 2008 | 01:42 PM
rockinthe94LS's Avatar
Default Re: Muffler rattle (ductmow)
try takin off the muffler and rinsing it out with the hose
Old Jun 27, 2008 | 04:27 PM
ductmow's Avatar
any1 else with ideas?
Old Jun 28, 2008 | 09:42 PM
JDM_LS's Avatar
Default Re: (ductmow)
i got a rattle on mine too, and its the gaskets on the exhaust, i need them replaced, and it sounds like rocks bouncing around in it, try that
Old Jun 28, 2008 | 10:23 PM
ductmow's Avatar
well i just got new gaskets so i doubt its that
Old Jun 29, 2008 | 04:47 PM
JDM_LS's Avatar
is your exhaust being held up be the rubber things that hold up the exhaust, my buddies does make that noise too, but its because he has it held up with chicken wire at one part of it. and if it is being held up by them, make sure that they are brand new ones, not reusing old ones. And if its not those things there must really be something inside the exhaust, mabey in the cat or the muffler tip itself if you cant get anything out with a hose. Good luck.
Old Jun 30, 2008 | 03:11 PM
jcidio's Avatar
my old trust exhaust rattled (at about 1.5-2k loudest normal driving wasn't noticeable) beacause the inside insulation wore out and the canister inside was loose. if that's the problem with your's there is no otherway to fix it except buying a new one. take the exhaust off and look inside while u shake it so u could see if it's loose
Old Jun 30, 2008 | 04:17 PM
ductmow's Avatar
toshko321
18
Jun 9, 2011 01:05 PM
K.Gallagher
Jul 13, 2006 08:04 PM
xakkkk
Nov 29, 2005 08:18 AM
steve_s
46
Aug 16, 2005 08:33 PM
runnin9z
Jan 16, 2005 10:39 AM
