Code 9- High Idle?
Old Jun 26, 2008 | 12:52 PM
SlipGear's Avatar
Default Code 9- High Idle?
I recently swapped a b18a1 into my Civic HB. Its all obd0 and i am running a pr4 ecu. The problem is that i am throwing a code 9 (TDC) code, and my car is idling at 1500rpm. IF i retard the dizzy all the way it runs at 1100 and if i advance it all the way it starts to idle surge 1000-1500rpm. Could the code 9 be causing this? I cleanded my IAC screen, and i blocked the FITV to see if it was that but it wasnt. I also bleed the cooling system of air. Thanks
Old Jun 26, 2008 | 01:22 PM
i-want-a-crx's Avatar
Default Re: Code 9- High Idle? (SlipGear)
whats a fitv sorry im not of help but i realy want to know
Old Jun 26, 2008 | 05:37 PM
SlipGear's Avatar
Default Re: Code 9- High Idle? (i-want-a-crx)
Fast idle thermal valve (?), it used for the fast idle when the engine is cold. Located beneath the throttle body.
99GreenEX
12
Feb 22, 2008 09:54 AM
c0nspire
Feb 23, 2006 02:09 PM
smokinsi
Jul 18, 2004 05:09 PM
Glocked1
12
Jan 22, 2004 08:13 PM
