Starting My Mini-Me Build Need Help!!!
Old Jun 24, 2008 | 07:08 PM
rangerxtrn's Avatar
Default Starting My Mini-Me Build Need Help!!!
Alright, I have a port/polished z6 head fully built ready to go, a skunk2 intake manifold, skunk2 megapower exhaust, megan 4-2-1 header, an aem tru-time cam gear, a 7lb fidanza flywheel, a stage 3 clutch kit, arp head studs, etc. I went with a z6 head and a y valve train and cam. Anyhow, any suggestions for piston/rod combos because I figure if I have the engine torn down that far might as well. I am doing a n/a build so I've been looking at eagle h-beams and cp or srp pistons... Do I buy d16z6 pistons or d16a6 pistons? Any decent gasket kit suggestions? ACL bearings? vtex controller? Any input would be much appreciated...
Modified by rangerxtrn at 8:15 PM 6/24/2008
Modified by rangerxtrn at 8:21 PM 6/24/2008
Old Jun 24, 2008 | 07:50 PM
vtecb18c's Avatar
Default Re: Starting My Mini-Me Build Need Help!!! (rangerxtrn)
any d series piston will fit....are you looking to do a stroker or some kind of boring the cylinders?? you want to n/a you have to start with the block...did you have any stroker kits in mind?
Old Jun 25, 2008 | 05:12 PM
rangerxtrn's Avatar
Default Re: Starting My Mini-Me Build Need Help!!! (vtecb18c)
well one of my friends mentioned golden eagle stroker kits, hadn't even looked at them but are told they are expensive... do you know of any reasonably priced kits out there? i was reading another thread about zc pistons in an a6 block with a z6 head making 12:1 compression? sounds a bit high... thanks for the input about the pistons... i was just worried about the clearances where the chambers are slightly smaller on the z6 head. i will have some pics up soon
importeclipsegst
Oct 14, 2011 02:17 AM
90-honda-crx-hf
Jan 16, 2011 08:09 PM
Solster
Jun 8, 2010 05:34 PM
tegra2G
10
Dec 22, 2008 04:45 PM
