Replacing stock Del Sol seat belts?
Old Jun 24, 2008 | 04:54 PM
mikeoxlodge's Avatar
Default Replacing stock Del Sol seat belts?
Hello,
I need to replace the passenger side seat belt.
Does anyone have any tips on how to do it easily? I don't want to screw up my interior!
Can I just replace the belt and leave the mechanicals in place?
Any suggestions would be appreciated.
Thanks,
Mike
95 Honda Del Sol
Old Jun 24, 2008 | 05:46 PM
OMGWTFBBQ!'s Avatar
I own an EK coupe, not a del sol, so things might be different.
The time and work it takes to just replace the belt is not worth it at all. The reel assembly is very complicated with the locking mechanism and the inversion mechanism that locks the belts if the car is upside down.
You will need to remove your interior trim in the back, and probably pull up the rear carpet in the foor wells.
If yours is similar to mine, your seat belt reel will be inset in the chasis, and you will need to unbolt your side impact bar/chassis reinforcement brace to get to the reel. Two bolts hold the reel on, once its out you unbolt the guide on your b pillar, and the anchor on the floor, then bolt in the new reel, and reassemble everything.
Old Jun 25, 2008 | 01:08 AM
JarvisW's Avatar
Sol to Sol
Default Re: (OMGWTFBBQ!)
Take it to your local Dealer, and get an appointment to have them replaced.
They are under lifetime guarantee if you haven't wrecked the car or used the belt to tow another car or something. (Seen weirder things lol)
I got mine done last year for free, and its great to have belts that retract again!!
spatula
Sep 14, 2009 01:45 PM
PinoyDelS0l
16
Jan 31, 2009 09:10 AM
cheesecheda
Aug 21, 2008 09:01 PM
vespid82
Mar 26, 2008 07:01 PM
underpressure02
12
Nov 2, 2004 07:59 AM
