Which HKS Turbo ?
Old Jul 18, 2002 | 09:27 AM
C-Murdock's Avatar
Default Which HKS Turbo ?
i was checking into the garret t30, but viren put me on to the hks dual ball bearing turbos...im running a fully built h22, and am looking for something around 15psi daily and 20-23 at the track, but im clueless when it comes to these hks turbos, there are so many different numbers and ****..2835 3040..etc etc....which one do you guys reccomend that would be somewhat like the t30 or a t3/t4e ball bearing, i want quick spool up, and the hks turbos are nice because they are also water cooled so i have no need for turbo timer...
thanks for the help....
Old Jul 18, 2002 | 09:55 AM
falcongsr's Avatar
What is this crap?
Default Re: Which HKS Turbo ? (C-Redrum)
have you checked pricing on the HSK turbos yet?
make sure you're sitting down first.
Old Jul 18, 2002 | 10:01 AM
C-Murdock's Avatar
Default Re: Which HKS Turbo ? (falconGSR)
yes, have already looked into that.....
Old Jul 18, 2002 | 10:04 AM
ArizonaTurbo's Avatar
The Garrett GT30 is an awesome turbo. Here are the specs I would go with the Garrett 705867-0002. Here are the specs:
T04S
.70 A/R Compressor Housing
56 Trim Compressor
T3
.82 A/R Turbine Housing
84 Trim Turbine
This turbo can easily support 500-550 whp adn it will have quick spool up time. HKS doesn't make a T3 based turbo that even comes close to these specs. Most of the HKS turbos are T25/T28 based turbine housings.
Old Jul 18, 2002 | 10:07 AM
C-Murdock's Avatar
Default Re: Which HKS Turbo ? (TurbochargedSER)
the only thing is, the gt30 has an internal wastegate, and i want an external wastegate....
Old Jul 18, 2002 | 10:12 AM
VaporTrail's Avatar
New User
the GT30 can be ordered with or without internal gate
Old Jul 18, 2002 | 10:22 AM
LEON's Avatar
.... and I believe the GT30 does come with a water cooled inner jacket?!?
Old Jul 18, 2002 | 10:31 AM
VaporTrail's Avatar
New User
Default Re: Which HKS Turbo ? (LEON)
that is also an option, at no additional charge
Old Jul 18, 2002 | 10:32 AM
C-Murdock's Avatar
Default Re: Which HKS Turbo ? (VaporTrail)
why wouldnt you want this option, this means no use of a turbo timer ?
Old Jul 18, 2002 | 10:34 AM
VaporTrail's Avatar
New User
your guess is as good as mine
Old Jul 18, 2002 | 10:41 AM
KekeK-18's Avatar
I use a tail 40mm wastegate with my GT30 and have water line running though the housing, I'll try to shoot some pic of it later.
The GT30 that I gave you a part number for is setup for an external wastegate. It does have a water cooled center section. Some people don't run water. I don't run water through my turbo and it is fine.
Old Jul 18, 2002 | 10:43 AM
C-Murdock's Avatar
do you still use turbo timer/ or let the turbo cool ?
Old Jul 18, 2002 | 10:45 AM
Turbo Timer
Old Jul 18, 2002 | 10:49 AM
C-Murdock's Avatar
is it a bitch to run the water ?
Old Jul 18, 2002 | 10:51 AM
VaporTrail's Avatar
New User
its not hard at all
Old Jul 18, 2002 | 11:01 AM
lbz34's Avatar
the gt series is the way to go. I have a good line on them for a decent price. i would sggest the gt 30 like everybody else.
acy76
Dec 28, 2005 07:33 AM
Cyber ITR
Jun 3, 2005 12:05 PM
Dee
Feb 28, 2005 05:53 AM
d98clturbo
Oct 3, 2003 08:37 AM
SpoonCivic
Oct 23, 2001 10:33 AM
