emanage wideband logging using omni 4 bar map sensor instead of greddy 3 bar?
Old Jun 24, 2008 | 12:13 PM
wilham320's Avatar
Default emanage using omni 4 bar map sensor instead of greddy 3 bar?
I have never been able to use the wideband logging feature with my blue emanage because it only has one port to either connect a 3 bar or a wideband. I have the greddy 3 bar hooked to because i run 20+ psi. Now that omni has the oem style 4 bar, can i just throw that into the stock spot and run emanage off that? the only question i guess is the omni the same scale (voltage) in vacuum as the stock map is or is it scaled differently. If it were read lower or higher it really F my map because it's a piggy-back ya know.....?
Modified by wilham320 at 10:13 PM 6/24/2008
Modified by wilham320 at 4:50 AM 6/25/2008
FWD_BEAST
Oct 9, 2012 04:24 PM
wilham320
Jun 25, 2008 09:37 PM
RACEPAK
Jul 23, 2006 02:32 PM
0-60n4
May 23, 2002 03:58 PM
0-60n4
May 22, 2002 07:39 AM
