Clutch Slave Cylinder?
Alright, how hard is it to install a clutch slave cylinder in my del sol? I have a D15b7 motor, would i need to remove my tranny in order to install the new one?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec2late »</TD></TR><TR><TD CLASS="quote">slave cylinder sits right in front of the tranny. 2 bolts 12mm wrench.</TD></TR></TABLE>So basically its self explanatory? I just want to make sure its not a hard thing to do lol, I have no time for my tranny to be taken off..Anymore info, would be kindly appreciated!!
All you have to do is remove the one on there, and replace it with the new one. VERY straight forward job. 2 bolts get it off the tranny, remove the hydro fluid line, reverse and bleed the clutch. You are good to go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">All you have to do is remove the one on there, and replace it with the new one. VERY straight forward job. 2 bolts get it off the tranny, remove the hydro fluid line, reverse and bleed the clutch. You are good to go.
</TD></TR></TABLE> I just did that a couple of minutes ago lol. Thank you though! I should haved looked before i posted something stupid like this lol. Thank you!
garyhgaryh
Jul 21, 2007 03:05 PM
ApolloSpeed
Feb 12, 2006 12:51 PM
