I screwed up! Putting back tranny... slave cylinder
Ok, so I finally got the tranny in my Civic Vx. I put the pin back in the extension rod (remember the "bitch piin"? That rod). So I go in to see if I can shift through the gears.
I push the clutch in and it goes all the way to the floor! Shoot! I'm not suppose to touch the clutch pedal until I attach the slave cylinder to the tranny. I go to the engine compartment, push the shaft all the way back into the clutch cylinder, and attach it.
I go back into the car and the clutch has very little resistance.
Did I screw up anything??! If I did, what needs to be done?
Thanks,
Gary
Thanks,
Gary
Re: I screwed up! Putting back tranny... slave cylinder (5_Lug_B)
That's good to hear. If the shaft goes out of the cylinder, wouldn't I have destroyed the seal since the shaft has never gone that far? It'll tear up the seal right?
Gary
Gary
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5_Lug_B »</TD></TR><TR><TD CLASS="quote">You need to bleed the clutch. Your fine </TD></TR></TABLE>
Yeah, you just let air into the lines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyhgaryh »</TD></TR><TR><TD CLASS="quote">That's good to hear. If the shaft goes out of the cylinder, wouldn't I have destroyed the seal since the shaft has never gone that far? It'll tear up the seal right?
Gary</TD></TR></TABLE>
It shouldn't tear up that seal - I've never seen that happen, anyways. I mean use ur eyes - attach the slave cylinder and see if it leaks when you clutch.
Though bleed it and it'll feel fine again.
blacklsvtec24
04-03-2008 12:04 PM
hspoon
11-20-2006 10:38 AM
