car won't go in gear properly (goes in gear when pedal is half way but wont when...
Old Jun 22, 2008 | 03:59 PM
GTEC913's Avatar
Default car won't go in gear properly (goes in gear when pedal is half way but wont when...
hey guys i searched and ask around but no answers. Well my problem is when i step on the clutch pedal all the way to the floor it won't go in gear but when i push it half way it goes in gear smoothly.. (new clutch kit, flywheel, throw out, clutch master cylinder etc.) things i did:
-bleed da clutch 5 times
-check to see if fork is moving
-check for leaks
Old Jun 22, 2008 | 07:46 PM
itsmejto's Avatar
Default Re: car won't go in gear properly (goes in gear when pedal is half way but wont when... (GTEC913)
That's a tricky one, but it has to be something you did wrong assembling the clutch parts methinks. I'ts overthrowing the clutch to the point where its binding up.
Old Jun 22, 2008 | 07:49 PM
gsrhatch2356's Avatar
there is a rod on the clutch master clyinder that can be adjusted, try that.
Old Jun 27, 2008 | 06:29 PM
GTEC913's Avatar
Default Re: car won't go in gear properly (gsrhatch2356)
anybody else... i took it apart and redid everything again with da help of my friend who is a mechanic and even he could not find out what was wrong.
codybb4
Dec 9, 2008 08:44 AM
viper_boy403
Aug 20, 2008 06:48 PM
Luchini
Oct 16, 2005 11:15 AM
hybrider
18
May 9, 2002 08:08 PM
