What is Stock ITR Alignment Setting?
Old Jul 17, 2002 | 10:10 PM
01CWITR's Avatar
Default What is Stock ITR Alignment Setting?
anyone know thanks !! i need to know
Old Jul 18, 2002 | 03:42 AM
Asahi's Avatar
Default Re: What is Stock ITR Alignment Setting? (TillerMan)
alignment shop should know stock settings. Toe is the only thing adjustable in stock form and should be Zero.
Why do you ask?
Old Jul 18, 2002 | 04:25 AM
La Chilindrina's Avatar
Default Re: What is Stock ITR Alignment Setting? (Asahi)
Toe-in front 0.0 in(0 mm)
Toe-in rear 0.08 in(2.0 mm)
Camber front -0°30'
Camber rear -0°45'
Caster 1°10'
Old Jul 18, 2002 | 04:27 AM
Willard's Avatar
Default Re: What is Stock ITR Alignment Setting? (Nined8integtypeR)
where were j00 when I posted dis?
https://honda-tech.com/zerothread?id=223097
Old Jul 18, 2002 | 04:29 AM
Default Re: What is Stock ITR Alignment Setting? (Willard)
awwwwwww.....
I was at school
Old Jul 18, 2002 | 04:47 AM
Asahi's Avatar
so what did you find out Will?
Old Jul 18, 2002 | 04:57 AM
DutchITR1689's Avatar
Camber front -0°30'
Camber rear -0°45'
Caster 1°10'
Wow!!! She is one hot walking Helms manual!!!
Old Jul 18, 2002 | 05:00 AM
Willard's Avatar
well....
here are my numbers... I will be double checking them at another shop soon (long story)....
__________LF_____RF
camber: (-0.77)_(-0.79)
caster:..(+3.15)_(+3.03)
toe:......(+0.02)_(+0.01)
__________LR_____RR
camber: (-0.62)_(-1.36)
toe:......(+0.08)_(+0.10)
I had the shop set the toe. The modification I did was suppose to add more neg. camber and add caster in the front... the caster was changed but the camber was not what I expected.
The lackie was very reluctant to folow my advice while he was doing the alignment and insisted me that he was doing it the 'right' way.
The use of EG Cibbic upper a-arms is suppose to add more camber... swapping them from side to side will add caster... but the added camber was not impressive.
After I check the alignment at another location to make sure the #'s match... I will put the ITR upper arms back on (still swapped from side to side) and drive.
The car felt better on track...
but I did swaybar changes also... and I am not sure if the alignment or the bars made the 'feel' better.
Will
Old Jul 18, 2002 | 05:12 AM
HalifaxITR's Avatar
I have an alignment printout, from when I had mine done. It has the specs. on it.
i.e.
camber: range
caster: range
toe: range
for LF,RF,LR,RR
I can post when I get home from work @ ~7pm AST
Old Jul 18, 2002 | 05:29 AM
RTW DC2R's Avatar
can someone add this to the archives or FAQ...I have some alignment issues that I will need to be dealing with in the near future and Id like to have these available when I need them. Search doesnt seem to work most of the time. Thanks
Old Jul 18, 2002 | 06:33 AM
RTW DC2R's Avatar
Default Re: What is Stock ITR Alignment Setting? (RTW DC2)
by the way, since we are on the topic of camber, Im just curious what kind of camber you guys run up front. I seem to get a lot of wheel hop, and I pretty much have no camber at all up front, and Im just wondering if maybe I run a little more negative camber that will help with that. Do you guys typically run a little negative camber, or try to have the least amount of negative camber possible? I plan to get the Z10 bars so that should help but I want to get the least amount of hop possible before I get the bars. Thanks
Old Jul 18, 2002 | 06:35 AM
Asahi's Avatar
I try to maintain right at or just under -2.0 degrees of negative camber. Works very well fo me. I have heard before cars will naturally "toe in" under acceleration and that you shoudl run toe out to compensate. I run 1/8" "toe out" but more for turn in than wheel hop.
Old Jul 18, 2002 | 06:57 AM
RTW DC2R's Avatar
So messing around with my camber, maybe adding some negative camber, could possibly help with my wheel hop situation? I am not sure what my toe settings are, but I will definitely keep it in mind next time I get the chance go get to the alignment shop.
Old Jul 18, 2002 | 10:38 AM
01CWITR's Avatar
oh the reason i am asking it just want to know some be4 i do the alignment ...
Old Jul 18, 2002 | 12:46 PM
Default Re: What is Stock ITR Alignment Setting? (DutchITR1689)
lol....whatever....
Just trying to help my fellow h-t peeps out
Old Jul 18, 2002 | 01:04 PM
HalifaxITR's Avatar
97->00 ITR Alignment Specs.
FRONT
Camber --> Specified Range -1.5 deg. to 0.5 deg.
Caster --> Specified Range 0.2 deg. to 2.2 deg.
Toe --> Specified Range -0.08 deg. to 0.08 deg.
Total Toe --> Specified Range -0.16 deg. to 0.16 deg.
REAR
Camber --> Specified Range -2.0 deg. to 0.0 deg.
Toe --> Specified Range 0.04 deg. to 0.16 deg.
Total Toe --> Specified Range 0.08 deg. to 0.32 deg.
texcon
Suspension & Brakes
Aug 5, 2013 06:27 PM
ribal_gh
Suspension & Brakes
Mar 24, 2013 03:53 AM
SportEL
Suspension & Brakes
29
Dec 20, 2007 06:46 PM
LX4CYL
19
Nov 1, 2004 11:53 AM
yoshi234
Dec 27, 2001 01:11 PM
