grinding when up and down shifting into 2nd.
Old Jul 17, 2002 | 08:45 PM
89 CRX SI's Avatar
Default grinding when up and down shifting into 2nd.
There is a slight grind mainly when downshifting from 3rd into 2nd gear. I have had this same grind when upshifting prolly like 1 in 200 times.
NE ways it will not grind if i wait and extra few sec to let ranny spin down then shift or if i double clutch downshift..
I think it is the synchros sound right? How hard and much is it to replace?
THX again guys
Old Jul 17, 2002 | 09:20 PM
89 CRX SI's Avatar
Default Re: grinding when up and down shifting into 2nd. (89 CRX SI)
ttt
Old Jul 17, 2002 | 09:51 PM
bryant's Avatar
Could be you just need your cluctch adjusted
But most likeley sounds like sycros are going. What tranny you have? That would give us a better idea of how much its gonig to cost
Old Jul 18, 2002 | 07:30 AM
89 CRX SI's Avatar
Default Re: grinding when up and down shifting into 2nd. (CR-X)
89 CRX Si tranny. I adjusted my clutch not sure if it is the corect way but i did. before it would nt spin the tires if i dropped it at 5000 in 1st. No i can go backwards drop it in first and spin. Clutch grabs great now but how would i know if i did it correctly.
Old Jul 18, 2002 | 07:36 AM
Bleed Black's Avatar
Do A SEARCH A-HOLE! J/K. I posted this EXACT problem a couple weeks ago. I changed my tranny fluid(as suggested) and the grinding is now less frequent. It actually never happens any more unless I try to down shift when going above 40 or so.
Old Jul 18, 2002 | 10:45 AM
89 CRX SI's Avatar
what tranny fluid should i use? a heavier one? list me some brands to buy and ill change it tonight
Old Jul 18, 2002 | 10:47 AM
SuperCivic's Avatar
HONDA MTF!!!!!!!!!!
Old Jul 18, 2002 | 04:03 PM
1990hondaHF's Avatar
Default Re: grinding when up and down shifting into 2nd. (SuperCivic)
I called the Honda dealership today and asked to speak with one of their tech guys. I then asked him about what I should put in my CRX SI trany...reg dino, simi-synthetic, Honda MTF, or Fully synthetic. He said that he had been there since 1988 and they have ALWAYS used Penzoil semi-sythetic. This make sence because the Honda MTF IS simi-synthetic. thats my $.02 worth of info.
Old Jul 18, 2002 | 04:07 PM
ncrx1's Avatar
Default Re: grinding when up and down shifting into 2nd. (1990hondaHF)
i had the same grind, i put in honda mtf and my grinds are all gone
mind u.. i didnt change my fluid for over 100,000km's with 2 trips to toronto and back.. so its my own fault
NYCz DA9
Jul 31, 2004 10:59 PM
NYCz DA9
Jul 16, 2004 04:38 PM
lshatchcx18
Jun 14, 2004 12:46 AM
MrBite
Jun 13, 2002 12:48 PM
JustChou
Apr 18, 2002 07:40 AM
