Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Spun bearing rod through block.Rebuild?Replace.
Old Jun 18, 2008 | 04:02 PM
Kongo69's Avatar
Default Spun bearing rod through block.Rebuild?Replace.
I recently did this to my poor civic. thought shed make it a few miles down the road.
What my questions are.
1.Can I easily tear down the engine and rebuild it with new rods pistons block and head maybe all from a a2 and use the a1 bottom end?
2. Would it be easier and more cost effective to just rip out the a1 and put in a a2 complete.
What im worried about is the engine being off balanced buy these parts.
Old Jun 18, 2008 | 04:23 PM
Boilermaker1's Avatar
another motor from the junk yard is $350 to 500. It would be more than that to machine and rebuild the old one.
Old Jun 18, 2008 | 04:37 PM
Kongo69's Avatar
Default Re: (Boilermaker1)
These Aholes around here want 1200-750.
ive been so careful with oil changes and PM stuff and i dont spin the turd all the way up.
could seafoam have caused it to over compress number one?
Modified by Kongo69 at 5:54 PM 6/18/2008
Old Jun 18, 2008 | 04:45 PM
andyman97's Avatar
Who knows what caused it. I don't use additives, I don't even use synthetic oil. No point. A lean condition from boost will do it every time. Check out http://www.car-part.com there are d17 motors a dime a dozen everywhere. [freak] 1k for that.
Old Jun 18, 2008 | 04:56 PM
Kongo69's Avatar
Default Re: (andyman97)
im not over simplifying what i think it takes to change these out right i mean its pretty straight forward.
Old Jun 18, 2008 | 04:58 PM
andyman97's Avatar
Change what out? The internals? There are tools you need and things you have to do. It isn't a simple 3 hour job.
Old Jun 18, 2008 | 06:24 PM
Default Re: (Kongo69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kongo69 &raquo;</TD></TR><TR><TD CLASS="quote">im not over simplifying what i think it takes to change these out right i mean its pretty straight forward.</TD></TR></TABLE>
If you're referring to the swap, its pretty straight forward. Drain and undo everything, then reverse. Thats oversimplified, but its just nuts, bolts, hoses and the wire harness.
Old Jun 18, 2008 | 08:08 PM
skipbarber's Avatar
you spun a bearing rod through the block? what on earth does that mean? You spun a rod bearing, a crank bearing or literally launched a rod through the block as a result of a spun bearing that seized?
either way, i bought a d17a1 in PA for $350 picked up from a junk yard with 16k miles (certified). like andy stated.. http://www.car-part.com is your best bet.
Old Jun 19, 2008 | 08:32 AM
Kongo69's Avatar
literally launched a rod through the block as a result of a spun bearing that seized.
It started knocking and i didnt drive it for a few days and it had to be moved Asap due to a crazy bitch throwing stuff off my deck.
drove it for a few mins at 55mph, and she the "D17" just said clunk clunk.
buddy said he saw some parts come out the botttom behind me. from what ive removed so far i can see a hole in the block on the fire wall side. number one pistion, with a little metal id tag folded out.
Old Jun 19, 2008 | 04:12 PM
skipbarber's Avatar
then the best thing to do is get a new motor. When i was shopping around, the best deals i came accross were in PA.
m4xwellmurd3r
Engine Machining & Assembly
Sep 15, 2016 11:14 AM
Cdude222
Aug 15, 2013 08:23 AM
pjr710
Aug 20, 2008 01:03 PM
f1 vtec
May 30, 2006 08:27 AM
808b18c1boosted
Apr 21, 2006 08:58 PM
