First time building an engine and I screwed up.. help?
Old Aug 13, 2013 | 10:55 PM
Cdude222's Avatar
Default First time building an engine and I screwed up.. help?
So last weekend I finished rebuilding my D16Y8 engine after blowing a piston. It's a eagle rod vitara .5mm oversize build with ACL bearings. Everything during the build gaped and gauged perfectly within service limit. (rod bearings .0015 mains I can't remember but below service limit) Now for the problem... during the breakin after about 7 miles of driving I began hearing a rattling noise and lost about a quart of oil (luckily only drove 2 blocks while the rattling was happening) by the rear main oil seal. Super pissed off I pulled the engine back out to check everything and noticed, i'm really upset to admit this, that I hadn't tightened down the flywheel bolts and the fly wheel was moving loosely. I know stupid mistake. Currently I am checking all the bearings to see if they are damaged beyond use and if I need to get anything else other than a new seal. Unfortunately i'm not well versed on whether or not to proceed with the bearings I have as i'm not sure how to tell if they are too bad to use again or if I can just throw them back in. (which i would prefer the second option as i've already spent quite a lot of money) So if I can get an expert opinion here are some pictures of a few of the worse bearing surfaces. How should I proceed?
P.S. I'm unable to feel the grooves to the touch
Old Aug 13, 2013 | 10:56 PM
Cdude222's Avatar
Default Re: First time building an engine and I screwed up.. help?
Oh and sorry about the photo quality
Old Aug 13, 2013 | 11:13 PM
Discosteak's Avatar
you suck at taking pictures lol. the bearings dont look to bad. what motor oil are you using?
Old Aug 13, 2013 | 11:21 PM
Cdude222's Avatar
Yea crappy camera, Bradd Penn SAE 30 break in oil
Old Aug 14, 2013 | 01:00 AM
Discosteak's Avatar
good. put it back together
Old Aug 14, 2013 | 07:20 AM
wantboost's Avatar
Who is Mr Robot?
The bearings to check in this situation would be the thrust bearings, as they would take most of tge abuse of a loose flywheel.
Check their condition and if they look ok reassemble the motor and check crank play front to back, put a dial indicator on the crank snout, 0 it out and use a small prybar to move the crank side to side (towards the oil pump and back to clear up any confusion about what you're checking) and see if it's within service limits. If there's too much play you need new thrust bearings
Old Aug 14, 2013 | 07:39 AM
Dark_Teg's Avatar
Bearings are cheap, I would replace them for peace of mind.
Old Aug 14, 2013 | 08:11 AM
Muckman's Avatar
Moderator in Chief
Looks like there is some dirty or debris in the oil. Make sure you flush the oil several times during break in.
Old Aug 14, 2013 | 05:55 PM
Cdude222's Avatar
The thrust washers look fine, It looks like I do have to have the crank machined unfortunately. Hopefully that should not mess up my bearing gap. Any suggestions of what else to look at?
Old Aug 15, 2013 | 08:23 AM
wantboost's Avatar
Who is Mr Robot?
If the journals have the be turned down you'll need thicker bearings otherwise the clearances will be way too large
integra3586
19
Aug 25, 2009 09:31 PM
pjr710
Aug 20, 2008 01:03 PM
LudemanDan
Mar 26, 2008 07:40 PM
Euro2JDM
Jan 10, 2007 01:23 AM
Dyzee
10
Apr 28, 2004 11:56 AM
