GSr popping outta gear... PLease help soon
Old Jun 16, 2008 | 01:34 PM
ABlais's Avatar
Default GSr popping outta gear... PLease help soon
I have a 94 del sol with a b16a and a gsr trannsimission. For some reason When im on the highway cruising it pops outta 5th gear. It doesnt happen with any other gear. The only thing i could think thats cuasing it is the fact that i have all hasport motor mounts except the tranny mount. The tranny mount is stock. Also the bushing on the shift linkage is a little torn up.. does anyone know the answer?
Old Jun 16, 2008 | 03:29 PM
superfast666's Avatar
Default Re: GSr popping outta gear... PLease help soon (ABlais)
its the tranny not the mounts
Old Jun 16, 2008 | 04:22 PM
ekb16's Avatar
have u changed ur tranny fluid yet?
Old Jun 16, 2008 | 04:28 PM
bsmith100's Avatar
Default Re: (ekb16)
Years ago this started happening to a friends car and he had to get his whole transmission rebuilt.
Old Jun 16, 2008 | 04:41 PM
jimmy o.'s Avatar
its the syncros or synronizers they need to be replaced had the same problem in my old probe had 5th gear rebuilt no problems since
Old Jun 16, 2008 | 04:43 PM
jimmy o.'s Avatar
it is not nessisary to rebuild the entire tranny I had two shops try to charge my over 1000 to rebuild a guy i had do it just fixed the problem for 275
Old Jun 16, 2008 | 05:19 PM
Civic_07's Avatar
mounts have nothing to do with this, change your 5th gear synchro.(Y)
Old Jun 16, 2008 | 06:23 PM
ABlais's Avatar
whats the worst that can happen with this? should i keep driving it or drop it off at a tranny shop tomorrow and get it fixed... will itblow my tranny?
Old Jun 16, 2008 | 07:19 PM
gsrhatch2356's Avatar
You dont even have to change the synchro. Its called a blocking ring and there is one on both sides of each synchro. it is what holds it in gear. if your synchro was bad it would grind going into that gear. if you have enough faith to tear it apart you could get one for like 10 bucks maybe even less.
Old Jun 16, 2008 | 07:21 PM
it wont do anything but be annoying. the worst thing that could happen is after long term use it could break up and get caught in the gears.
ABlais's Avatar
Default Re: GSr popping outta gear... PLease help soon (gsrhatch2356)
lol i dont have enough bals to tear it apart, but how much do you thing a tranny shop would charge to do it?
Old Jun 16, 2008 | 07:30 PM
good guess is probally around a grand. cause once they get in there they are going to reconmend everything that needs to be replaced. so and if certain gears on the coumter shaft are messed up then you have to get another counter shaft only certain gears come off. and those same gears can be changed on the main shaft.
Old Jun 17, 2008 | 11:25 AM
bsmith100's Avatar
It seems like the biggest challenge will be finding an honest mechanic or shop who can fix that single gear without trying to charge you for a complete rebuild of the whole transmission.
BULL3TPR00F
Feb 14, 2012 10:00 PM
92EG8
10
May 1, 2007 04:35 AM
RED DA
Feb 10, 2007 12:52 PM
lawlerlaw
23
Apr 21, 2006 09:11 AM
rac3rb0i
Nov 30, 2004 11:02 AM
