starting problem w/ 90 civic 1.5L
Old Jun 16, 2008 | 12:22 PM
stealth_EK4's Avatar
Default starting problem w/ 90 civic 1.5L
I just picked up a 90 civic wagon and it has the 1.5L engine, It has a little starting issue, once in a while it starts fine sometimes it just cranks and doesn't start I will let it sit like 20 min and try again then it will start but slowly start. also once in a while while im at idle the engine light will come on and the idle quickly raises about 300 rpm higher, and after that point usually is when it wont start, but eventually it will, I just picked it up 4 cheap w a blown head gasket, I swapped that out and the fuel filter and thats all, It had the starting problem before I swapped the gasket. What could it be? ignition or fuel problem idle sensor? I will run the trouble codes later on today.
thanks
Ryan Lwin
Sep 8, 2012 07:41 PM
civicb16eg
12
Mar 3, 2009 11:56 AM
omg_jdm
Feb 26, 2009 07:23 PM
busyychild
May 11, 2007 05:13 AM
EF8_SiR
Aug 29, 2002 01:22 PM
