Classic Hondas All Pre-1988 Hondas.
5spd transmission swap question
Old Jun 16, 2008 | 10:20 AM
ejp2fast's Avatar
Default 5spd transmission swap question
I have a 1987 accord LXi 2.0 and the tranny lost 5th gear. I found another 5spd transmission out of a 1988 carbed model 2.0 that is good. Is there any difference in transmissions between these two? If i recall, only the carb models were in canada. I can get this fairly cheap, and would it be an equivalent tranny to the one that I have in? Is there any reference to another thread or website on these transmissions? Is it the same gear ratios? thanks in advance.
Old Jun 16, 2008 | 01:48 PM
2ndGenGuy's Avatar
Default Re: 5spd transmission swap question (ejp2fast)
They'll swap right across. The ratios are slightly different, but it should be barely noticeable. Carb'd and PGM-FI models were available throughout the world. Check 3geez.com FAQ for the proper ratios.
Old Aug 15, 2008 | 05:39 AM
ejp2fast's Avatar
Default Re: 5spd transmission swap question (2ndGenGuy)
ok, so i got a transmission out of a 1988 accord (don't know trim level)
everything seems to be OK, except..... the starter. On my 87 lxi, the starter diameter is about 2.5". on the 88 that i want to put in, its 3". any possible way to put a 88 starter and solenoid in? anybody else know about these different diameters? HELP
komat
Oct 28, 2013 02:36 PM
agentx
Classic Hondas
Sep 19, 2008 11:06 PM
nowind
Nov 2, 2006 11:31 PM
JeepinGoose
Feb 24, 2006 09:17 AM
Schmitey
Jul 16, 2004 09:03 PM
