Engine keeps dying
Old Jun 16, 2008 | 10:16 AM
ole haus's Avatar
Default Engine keeps dying
I own a 2000 civic 1.6 150000 miles. yesterday I replaced timing belt,waterpump. Since i was already fixing I replaced plugs,dist cap, rotor,wires. car started and ran very well. on the way to work when at stop light it died when restarted I noticed very low idle and wanted to die again is there a sensor that is going out ? Im looking for any help on were to look at problem any help apreciated thanks
Old Jun 16, 2008 | 10:18 AM
maxaldinger's Avatar
Default Re: Engine keeps dying (ole haus)
probably the alternator, check to make sure the belt is tight enough.
Old Jun 16, 2008 | 01:38 PM
blindguy's Avatar
Default Re: Engine keeps dying (maxaldinger)
almost identical problem with my 2000 civic. ive been advised to check my TPS and 02 sensor maby? as well as well the IAVC. just start with one of em bro.
Old Jun 16, 2008 | 05:48 PM
tortis's Avatar
Default Re: Engine keeps dying (blindguy)
is your distributor adjusting nut tight. dizzy might have moved.
Old Jun 16, 2008 | 05:51 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Engine keeps dying (tortis)
ok before you go napalming sensors, look at what you did.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ole haus &raquo;</TD></TR><TR><TD CLASS="quote">I own a 2000 civic 1.6 150000 miles. yesterday I replaced timing belt,waterpump. Since i was already fixing I replaced plugs,dist cap, rotor,wires. car started and ran very well. on the way to work when at stop light it died when restarted I noticed very low idle and wanted to die again is there a sensor that is going out ? Im looking for any help on were to look at problem any help apreciated thanks</TD></TR></TABLE>
1 - timming belt.
is it on correctly?
2 - water pump
is there an air pocket? this will wreak havoc
3 - tune up stuff
is this stuff installed correctly
look at your coolant level first. and then check the stuff you changed as it ran fine before this excursion?
ESCostilla
May 4, 2018 08:03 AM
Jack jaxz
Mar 25, 2016 07:43 AM
Honda81
Aug 31, 2010 04:35 AM
jigger
Jul 28, 2008 11:24 AM
deputydawgg
25
Jul 1, 2004 12:22 PM
