2000 Civic Oxygen Sensor
4 cylinder 2000 Civic with 6,700 miles. Check engine light is on. AutoZone read codes PO136 & PO137. Both codes are for oxygen sensor 2 in bank 1. PO136 says a malfunction exists in electrical circuit for the sensor. PO137 says input voltage from sensor is too low for current operating conditions. Because car is driven so seldom, I'm not concerned about poor gas mileage. Car is running fine so fuel mixture must not be lean. Dealer quoted $220 to replace sensor and said engine isn't being damaged as long as fuel mixture isn't lean. I don't want to spend money to replace sensor. Will there be any problems? I've read some posts about overheated oxygen sensors melting in the catalytic converter?
Resident Gearhead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenej8power »</TD></TR><TR><TD CLASS="quote">Before you know it your cat will go out.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jigger »</TD></TR><TR><TD CLASS="quote">Both codes are for oxygen sensor 2 in bank 1.</TD></TR></TABLE>
Maybe I've had too much to understand. 02 sensor #2 in bank 1??? Is that the 02 sensor downstream of the cat converter? If so that sensor's sole purpose is to monitor if the cat is healthy and doing it's job correctly - it has nothing to do with fuel dosage.
Re: (mcvtec) location of oxygen sensor
Sorry for the delay in replying. I was looking for the AutoZone report. It says oxygen sensor 1 is closest to the cylinder head before the catalytic converter, while oxygen sensors 2 & 3 are located further downstream and are typically mounted in or after the catalytic converter. It also says bank 1 identifies the location of cylinder while bank 2 identifies the cylinders on the opposite bank. Clear as mud?
Re: (mugenej8power) 2000 Civic with 6,700 miles
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenej8power »</TD></TR><TR><TD CLASS="quote"> 2000 Civic with less than 7,000 miles? Is it all original? I demand pics.</TD></TR></TABLE>
The mileage is accurate. The car belongs to a senior citizen. Everything is original.
Jwbetley
Engine Management and Tuning
11-15-2008 04:44 PM
kbw2000civicex
27
11-06-2008 07:27 AM
