boosted h23a1
Old Jun 16, 2008 | 09:49 AM
coojoe59's Avatar
Default boosted h23a1
i have a 93 lude h23a1 and i have just recenly boosted it. i am running around 15 pounds of boost does anyone know how i can safly turn the boost up before blowing it up?
Old Jun 16, 2008 | 10:17 AM
Hawkze_2.3's Avatar
Default Re: boosted h23a1 (coojoe59)
More info dude. What is your setup?
Your psi is already way too high if you are using stock pistons.
Old Jun 16, 2008 | 03:36 PM
mattsnooz's Avatar
sky's the limit kiddo. And tunings the clouds. I've already said a prayer for your motor though.
so 15 psi, netting you how much horsepower is still not enough? I gotta hear this.
It could be time to upgrade to a different car maybe. Unless you want to build your motor for the turbo second time around. Don't be afraid to work backwards though. If you have too, pull your turbo system off, and build your block. If not, just crank that boost up!
Old Jun 16, 2008 | 04:05 PM
h23siaws's Avatar
Default Re: boosted h23a1 (mattsnooz)
8 - 9 psi on stock block with moderate tuning. basically more tuning = more psi. but 15 psi on stock block is death. but goog luck
Old Jun 18, 2008 | 09:42 AM
coojoe59's Avatar
i have a rebuild with better pistons and head and cams you know all the works. just wandering what would be better. oh yah i am around 450 hp with 15 pounds running a 12.64 1/4.
Old Jun 18, 2008 | 09:47 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coojoe59 &raquo;</TD></TR><TR><TD CLASS="quote">i have a rebuild with better pistons and head and cams you know all the works. just wandering what would be better. oh yah i am around 450 hp with 15 pounds running a 12.64 1/4.</TD></TR></TABLE>
No, you don't seem to understand. WHAT IS YOUR SETUP? That means what exact parts do you have, is the block sleeved, what turbo are you using, what engine management, etc??
You do not have 'all the works'.
BOMBCRU
Aug 4, 2022 08:21 PM
Dugdude
Aug 25, 2013 11:43 PM
civic_jdm16
May 20, 2007 11:31 AM
Big Bang
Aug 12, 2004 01:38 PM
p1ccoloz
May 2, 2003 01:43 PM
