How Much boost???????????????
Old May 19, 2007 | 02:30 AM
civic_jdm16's Avatar
Default How Much boost???????????????
OK I am about to boost my B17A1..... How many pounds of boost should I run?????
The motor is bone stock....
Old May 19, 2007 | 02:47 AM
mike5809's Avatar
Default Re: How Much boost??????????????? (civic_jdm16)
25 + 200shot
um do a search you can find so much info. It all depends on your motor and what you want out of it.
But im assuming you have alot of miles on a b17 so I would say 6-8psi with a stock bottom end.
Old May 19, 2007 | 03:05 AM
Default Re: How Much boost??????????????? (mike5809)
Ok what if I would put a block guard in, and a thicker head gasket?????
Since every pound of boost = a 7% H.P. increase... I would like to run 15 psi and double what I have now
Old May 19, 2007 | 04:14 AM
dorifto_83's Avatar
why 15 lbs, pffft I would do 30
Old May 19, 2007 | 07:11 AM
mike5809's Avatar
If you do 15 you will most likely blow your engine up.
To get that high your going to need shotpined or forged rods, at least some arp rod bolts and head studs, forged pistons, block guard or sleeve (when you get 15+ psi the cyl walls tend to flex a bit therefore you might crack em), and all other things with a rebuild seals and bearings and ****.
Along with all supporting mods; fuel (inj, fpr, pump (maybe), air, exhaust, clutch, ecu tuned, etc)
Your looking at spending alot of money to get to 15psi
The stock rods and rod bolts and sleeves should be able to handle 6-8,9 with no/minimal problems
Have you done a compression check on your motor first?
Gl doing that to a b17.
Old May 19, 2007 | 07:31 AM
LoseRPunKx182's Avatar
i like to stop at 10psi for most stock hondas to be on the safe side. and please dont make a post on topics that show up atleast 10 times a day. its been discussed plenty and can be found if you just search.
good to see some locals tho...
Old May 19, 2007 | 08:49 AM
PistolStarta's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike5809 &raquo;</TD></TR><TR><TD CLASS="quote">25 + 200shot
But im assuming you have alot of miles on a b17 so I would say 6-8psi with a stock bottom end.</TD></TR></TABLE>
haha, I like the randomly added nitrous shot
Old May 19, 2007 | 09:16 PM
Default Re: How Much boost??????????????? (LoseRPunKx182)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoseRPunKx182 &raquo;</TD></TR><TR><TD CLASS="quote">good to see some locals tho...</TD></TR></TABLE>
What part of Pa are you from??????
Old May 19, 2007 | 09:22 PM
Jtuned DC2's Avatar
* B A N N E D *
Are you thinking about just puttin a turbo kit onto your b17a? Not even touching the internals? If so 10 psi Is safe for you. And are you buying a turbo kit? How many miles does your engine have? WE NEED DETAILS
edit: Buying as in buying a complete turbo kit, or custom making one
Old May 19, 2007 | 09:49 PM
Dartanian's Avatar
What sized turbo and what engine management?
Different sized turbos make different amounts of power at a given psi. Power kills engines, not psi.
The engine management is key to reliability. Half *** this and any psi will blow your motor up.
Old May 19, 2007 | 09:54 PM
Default Re: (KevLo)
Well millage is unknown but the motor is CLEAN!!!!!!!!! NO carbon build up at all!!!!!
There is not even any gunk on the oil sump...... I have a turbonetics turbo kit T3T4
I am planing on putting in a block guard, head gasket spacer, and if I get this new job a good set of cams and a intake manifold.......
If I get mid 13's I will build the motor...... I once ran 15psi on a single cam with no problems, it had spacer, block guard, and obx intake.....
Old May 19, 2007 | 10:27 PM
Dartanian's Avatar
Default Re: (civic_jdm16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_jdm16 &raquo;</TD></TR><TR><TD CLASS="quote">Well millage is unknown but the motor is CLEAN!!!!!!!!! NO carbon build up at all!!!!!
Have you performed a compression and leakdown test yet? That is a better estimate of the engine's health than how clean it looks inside.
T3/T4? What size? I am going to assume a 57 trim. What engine management?
Old May 19, 2007 | 10:55 PM
lsvtek's Avatar
Default Re: (Dartanian)
before you go turbo, make sure your motor is good.Run a comp test and compression test. Like others have stated, 10 PSI is safe to be on a stock block. But id still go lower like at 7 psi to really make sure
Old May 19, 2007 | 11:04 PM
No I have not tested it yet..... I have a compression tester but I am not shure how to use it and no leak down check yet........
I am not shure about the turbo size but the inlet is 2 1/4 inch
I am thinking the motor probably has around 80 to 90 thousand on it
It has been ran on 10/30 castrol syntec blend since I had it.......
But it was real clean to begin with....
Just realy want to be fast with no problems
If it helps the original trany is still on the motor Ys1, and there are no problems with it........
Old May 19, 2007 | 11:21 PM
98BabiGs-T's Avatar
I would say run 8psi for DD... 10psi if your pushing it...
Old May 19, 2007 | 11:34 PM
Dartanian's Avatar
Answer my question!
Old May 19, 2007 | 11:52 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
Dont go by psi, its how much power your putting down. That turbonetics turbo is most likely a t3/t4 and should be able to give you more that enough HP your stock blocks recomended whp, which is 280-300whp. No block guard will be needed(search blockguard and decide wether they help or are a waste of money). I personaly dont think they do much but constrict the sleeves from expanding while in high temperatures, but thats just my opinion and i know people will disagree. If you have the money for cams then great, look into buying some ctr or 2000-2001 itr cams. Also dont forget a clutch and a good tune.
But before you turbo it, you should do compression check.
Old May 20, 2007 | 09:13 AM
Default Re: (jdm_dc_fan)
I am running an act clutch pro-lite flywheel heavy dudty preausre plate and modified street disc the setup can handle 250 ft. lbs. of touqre
I don't think I will be getting to that anytime soon.......
Old May 20, 2007 | 09:55 AM
Schister66's Avatar
Man U FTW
psi doesn't mean a thing...power kills engines
stop this meaningless bullshit and give out useful information...
Old May 20, 2007 | 10:11 AM
Default Re: (Schister66)
agreed...i wouldn't push more than 300hp. sorry about that
Old May 20, 2007 | 11:31 AM
1.8L_allmotormilitia's Avatar
lol
BOMBCRU
Aug 4, 2022 08:21 PM
ek-j
12
Jul 28, 2008 08:04 PM
coojoe59
Jun 18, 2008 09:47 AM
924doorEG
Mar 9, 2008 11:01 PM
mozez
Jan 13, 2004 08:48 PM
