block guard question
Old Jun 15, 2008 | 12:41 PM
bertsb18hatch's Avatar
Default block guard question
im trying to figure out if i should install one or not. my setup is b18a1 block 81.50mm, wiseco 11.4:1 pistons, eagle rods, exospeed stage 3 b18a1 head, ported and polished, supertech valvesprings and retainers, stainless steel swirl polished valves, brian crower stage 2 camshafts, blox intake manifold, blox 70mm tb, jdm 4-1 header 2.5"collector, golden eagle fuel rail, b&m fuel pressure regulator, short ram intake w/ blox velocity stack, b16 tranny, 12.5 lb. lightweight flywheel, and im also using a zex nitrous kit 75 shot. a friedn told me to get a blokcguard and install when were putting motro together, and i want to get someone else's opinon. also will be installing my 310 injectors when i convert to obd1
Old Jun 15, 2008 | 01:29 PM
Runnerdown's Avatar
Default Re: block guard question (bertsb18hatch)
I vote no. extreme cylinder pressure on stock sleeves will cause problems if a blockguard is there or not.
Old Jun 16, 2008 | 06:11 AM
FST GSR 1's Avatar
Default Re: block guard question (Runnerdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">I vote no. extreme cylinder pressure on stock sleeves will cause problems if a blockguard is there or not. </TD></TR></TABLE>
I wouldn't put one in though if you aren't planning on machining afterwards. Blockguards are a .0007 - .001 Press fit and anything over .0005 is a tight PF that will move material. The right way is to install and then machine.
Old Jun 16, 2008 | 06:21 AM
b19coupe's Avatar
No. Don't need it.
Old Jun 16, 2008 | 09:22 AM
mar778c's Avatar
Community Builder
Community Influencer
No, you don't need it.
bertsb18hatch
Jun 9, 2008 03:12 PM
bertsb18hatch
May 5, 2008 09:57 PM
Razr2
13
Feb 24, 2008 04:26 AM
sharno
Jul 15, 2006 03:05 PM
wrXtian
May 12, 2003 01:50 PM
