nitrous question
Old Jun 7, 2008 | 08:55 AM
bertsb18hatch's Avatar
Default nitrous question
right now im running a b18a1 with a b18b1 head with crower stage 1 cams and valvetrain,blox intake manifold, golden eagle fuel rail, stock throttle body,cold air intake, jdm 4-1 header 2.5" collector, stock injectors, chipped pr4 ecu with basemap(not tuned), b16 tranny, 12.5lb flywheel, and zex dry nitrous 75 shot. i just ordered a exospeed stage 3 head that ported and polished, supertech valvetrain, stainless steel swirl polished valves, brian crower stage 2 cams, blox 70 mm throttle body, and im trying to figure out what pistons and rods to buy for the motor. i want to go high compression but still spray the car. does anyone have any suggestion on a piston rod combo and what compression ratio? also i plan on getting a obx lsd and a set of stage 2 axles.any suggestions will help
Old Jun 8, 2008 | 01:02 PM
Default Re: nitrous question (bertsb18hatch)
noone?
Old Jun 8, 2008 | 01:35 PM
Garage 808 Hatch's Avatar
cheap *** eagle rods will do anything it sounds like you want to do. as far as pistons, there are tons of options. you can do in the 10s:1 on pump and probably mid 11s:1 on 110 or better with a tune. i really like the Mahle piston kits. many dont, but i have had great success with them boosted and in sprayed applications. they are pretty cheap, skirts are coated etc. they only offer a few comp ratios is the problem
Old Jun 9, 2008 | 10:11 AM
B18cHatch06's Avatar
Any forged piston such as JE, wiseco, CP ect. will do fine with a set of eagle rods or something similar. i'm currently running JE 11:1's with stock rods that are shotpeened with arp rod bolts for the past 3 years. This motor has been on a "100 shot" on 93 octane for quite some time going through endless bottles. i plan on putting bigger jets in to make a true 100whp more on spray since my motor seems to love it and has shown no sides of being hurt.
Old Jun 9, 2008 | 11:59 AM
Default Re: nitrous question (B18cHatch06)
ok thanks for the info what times are you seeing with the 100 shot
Old Jun 9, 2008 | 03:08 PM
Top Ramen's Avatar
Don't worry about the nitrous; just build it as if you were doing a normal aggressive NA motor. It will love the spray if you tune it right.
Old Jun 9, 2008 | 03:12 PM
projectTeG's Avatar
ok, here a question i too am going the nitrous route, and i have a Ls/vtec with factory ITR pistons, are the factory pistons ok for a 100 shot?
bertsb18hatch
Sep 15, 2009 08:41 PM
bertsb18hatch
Jan 17, 2009 02:54 PM
K-Drum
Feb 21, 2005 10:45 AM
gsracer170
25
Oct 30, 2003 09:20 AM
b00stedbyFastrax
Aug 27, 2002 04:10 AM
