CHECK ENGINE LIGHT CODE P-1259????
Old Jun 15, 2008 | 11:55 AM
36Chitownrunnin's Avatar
Default CHECK ENGINE LIGHT CODE P-1259????
I got a check engine light on my honda with gsr swap no more faults expect p-1259 and p-0118 can anyone help me? I think the 0118 is coolant maybe but I can find the p-1259 .
Old Jun 15, 2008 | 12:06 PM
elektronsi's Avatar
Default Re: CHECK ENGINE LIGHT CODE P-1259???? (36Chitownrunnin)
p-1259 is "VTEC system malfunction" my EM1 threw that code about 4months ago heading home from vegas, when vtec engaged passing a semi, i took it to my buddies shop, he checked it all out and said that sometimes when vtec engages the oil pressure to the solenoid will drop slightly throwing that code, nothing to worry about, just kind of telling you to check your oil level(vtec motors naturally burn oil when revved high up) he reset the code for me and said that its nothing to worry about, just a precationary thing. not sure if thats what your problem is but that would be my guess
P.S.
here's a list of CEL codes:
https://honda-tech.com/zerothread?id=682412
Old Jun 15, 2008 | 04:51 PM
Default Re: CHECK ENGINE LIGHT CODE P-1259???? (elektronsi)
thank you for the link. was kinda of worried. but when i was wiring it to the connector the vtec oil has 2 wires only room for 1 where do i put the other wire??
Old Jun 15, 2008 | 05:10 PM
count me out's Avatar
* B A N N E D *
ground it to the the bolt on top of the solenoid.
Old Jun 15, 2008 | 05:14 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elektronsi &raquo;</TD></TR><TR><TD CLASS="quote">p-1259 is "VTEC system malfunction" my EM1 threw that code about 4months ago heading home from vegas, when vtec engaged passing a semi, i took it to my buddies shop, he checked it all out and said that sometimes when vtec engages the oil pressure to the solenoid will drop slightly throwing that code, nothing to worry about, just kind of telling you to check your oil level(vtec motors naturally burn oil when revved high up) he reset the code for me and said that its nothing to worry about, just a precationary thing. not sure if thats what your problem is but that would be my guess
P.S.
https://honda-tech.com/zerothread?id=682412</TD></TR></TABLE>
its not a precautionary "thing". the solenoid just engages as long as the pressure switch tells the ecu there is adequate oil. the solenoid has nothing to do with oil pressure.
Old Jun 15, 2008 | 05:23 PM
Default Re: CHECK ENGINE LIGHT CODE P-1259???? (count me out)
hmm... so if I bolt the ground to the top of the solenoid it will fix the problem?where do I ground it in the engine bay or on the pcm connectors? Also would you know anything about the ECT engine coolant temp high circuit input what would cause this light to come on. Thanks for the help
Old Jun 15, 2008 | 07:45 PM
* B A N N E D *
3 wires from ecu, 2 to pressure switch, 1 to solenoid, ground the second wire coming out of solenoid to the solenoid.
Old Jun 17, 2008 | 08:44 PM
did what you said and no more faults thanks, other than o2 but that whats happen when you dont have 2nd o2
vtec8804
Oct 20, 2006 07:56 AM
greencivic1029
Sep 2, 2005 08:57 AM
Cedor
Jun 4, 2005 06:51 PM
McNizzle
Apr 28, 2004 05:44 AM
typer_801
Mar 19, 2002 07:08 AM
