auto to manuel
you can deff find this in a search cause this is were i looked to find out what i needed. are you doing the swap yourself? i got a donor car from a junk yard and had a friend mechanic do it. off the top of my head youll need manual guages, master cylinder, clutch pedal, new shifter, the tranny... just search in " archived" it helps. i payed 1350 for parts and install...
the search was not hard... went to search typed in manual swap, clicked archived, came up with 4 posts 1 of them being mine!!!! here.
the actual transmission,
the clutch,
the flywheel,
the 3rd clutch pedal,
the slave cylender,
the shifter,
the shift ****/boot,
the clutch line,
the master slave cylender,
and.... the manual speedoometer guages
the clutch,
the flywheel,
the slave cylender,
the shifter,
the clutch line,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitexpinoy »</TD></TR><TR><TD CLASS="quote">you can deff find this in a search</TD></TR></TABLE>
I wouldn't criticize if I were you.
Examples:
Yours => Where it belongs
Note the last post you made
Examples:
transmission
shift cables
shift box
clutch lines: hardlines, softlines, and slave cylinder
master cylinder for the clutch
and manual trans speed sensor if the new trans does not come with it
manual trans starter
mastercylinder rezzy and cap
clutch pedal assy
brake pedal assy
flywheel and flywheel cover
manual subframe
manual trans motor mounts
manual gauge cluster
Manual ecu
manual wiring harness
shift cables
shift box
clutch pedal assy
brake pedal assy
manual subframe
Manual ecu
Having done this swap i have first hand experience on whats needed and not. You do not need the ECU, Engine Harness & Dash Harness. Although its best you change them you wont need them to have the car running. You will throw CEL's for missing senors and have no reverse lights. Just make sure you reconnect the little black box that's located on the auto tranny on the side back on the car (be sure its set in park)
You will need these parts
-Trans w/ Slave, Starter, Speed & Reverse Sensors (preferably from a 04-05)
-Flywheel & Clutch w/ Flywheel Cover
-Subframe
-Axles
-Front Tranny Mount & Side Tranny Mount Bracket (the automatic side mount, rear mount & bracket fits)
-Shifter Box w/ Cables
-Brake & Clutch Pedals
-Clutch Master Cylinder w/ Reservoir
-Clutch Hard & Flex Line
Not needed but recommended
-ECU
-Engine Harness
-Dash Harness
-Gauge Cluster
Modified by JDMInspired at 2:53 PM 7/3/2008
-Subframe
-Axles
-ECU
-Engine Harness
-Dash Harness
-Gauge Cluster
lowsinthe20s
Aug 10, 2006 03:56 PM
