need help skunk2 setup
ok ill start with everything...i have a 2000 gsr full swap in a 93 eg i just recently sent the head in to the machine shop to get rev valve train dual springs titanium valves and retainers with skunk2 stage 2 cams...a couple questions....
What do i set the valve adjustment to i have all them set at .007???
when i hit 5 grand when vtec pops it breaks up which i think its tuning but after 6500 it pulls hard...
and does anyone have any ideas to make it run harder i have adjustable cam gears the skunk2 pro series should i advance or retard any of them??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcivic92 »</TD></TR><TR><TD CLASS="quote">ok ill start with everything...i have a 2000 gsr full swap in a 93 eg i just recently sent the head in to the machine shop to get rev valve train dual springs titanium valves and retainers with skunk2 stage 2 cams...a couple questions....
I didn't see you mention anything about what ecu/tuning software you're running so I'm assuming you're running a stock gsr ecu, if that's the case, then definately get a tune. Leave the cam gears at 0 and have your tuner adjust them during your dyno tuning session.
95civickid
Oct 27, 2008 02:52 PM
MR_FIX_IT
25
Jul 19, 2008 10:10 PM
QWKPHKR
Nov 27, 2002 05:36 PM
