top radiator hose hot
Old Jun 14, 2008 | 06:52 PM
flatblack-h22's Avatar
Default top radiator hose hot
I just put in a jdm h22 and my top radiator hose it hot and the llower one isn't. thought it might be the thermostat but I took it out and it still hot.
jdm h22 in a eg
Old Jun 14, 2008 | 06:55 PM
Frozen E's Avatar
H-T White Ops
top will be hotter than the bottom one. Coolant comes out of the engine and enters at the top. As it cools it gets down to the bottom part of the radiator and goes back up inside the engine. Normal coolant flow my friend.
I bet if you were to let the car idle for about 15 minutes, or just drive it for a few and checked the hoses again, the bottom one would be warm, not cold, and the top one would be at whatever temp your t-stat is preset for.
Old Jun 14, 2008 | 07:00 PM
Default Re: (IslandSi)
forgot to mention that you can hear the water in the resevoir is boiling.
Old Jun 14, 2008 | 07:14 PM
Frozen E's Avatar
H-T White Ops
Highly doubt that. Probably air being pushed out. Why'd you take the stat out in the first place? After you did that, did you properly bleed the system? I'm going to guarantee you that you have an assload of air in your cooling system you need to take out.
Do a search for "bleeding cooling system" on here and do that after you replace the stat.
B18c1vicrx
May 13, 2009 01:01 PM
gabrielle
Apr 18, 2007 09:18 AM
-Championship-
Nov 26, 2006 07:14 PM
whiteboy4life74
Aug 26, 2004 08:07 AM
drumsy
Sep 12, 2002 07:14 AM
