HELP NEEDED WITH 91 CRX SI B-SERIES SWAP (AXLES)
Old Jun 13, 2008 | 05:31 PM
BoRiCuA's Avatar
Default HELP NEEDED WITH 91 CRX SI B-SERIES SWAP (AXLES)
I've used the Search button, but all the misinformation from he said she said is just wack. So if n1 with some hands on experience can chime in i'd really appreciate it.
1991 crx si
93 gsr block with half-shaft
ys1 cable tranny
what axles i use with this type of half shaft?
do i need to switch spindles?
Old Jun 13, 2008 | 05:51 PM
SlipGear's Avatar
Default Re: HELP NEEDED WITH 91 CRX SI B-SERIES SWAP (BoRiCuA)
Sorry, I misread your post. Yes you need 90-93 Integra Axles
Modified by SlipGear at 6:59 PM 6/16/2008
Old Jun 13, 2008 | 06:17 PM
BoRiCuA's Avatar
Default Re: HELP NEEDED WITH 91 CRX SI B-SERIES SWAP (SlipGear)
I have a cable trans ys1.......out of the search ive done 1st time ive heard of this
Old Jun 13, 2008 | 06:35 PM
SIred91's Avatar
Rainman
The axles you use MUST match the half shaft and transmission.
Non--abs.
Old Jun 13, 2008 | 06:55 PM
Janos Lin's Avatar
Default Re: HELP NEEDED WITH 91 CRX SI B-SERIES SWAP (SIred91)
The half shaft will go in any cable or hydro transmission. Only difference is with 92 or 93+ trannys, u need to use a different driver's side oil seal to accomodate the difference in the seal diameter. In other words, use the seal that goes with the half shaft.
As for the axles, that depends on the halfshaft you have. Go here for the axles, http://raxles.com/hybrids.aspx. If ur not sure, u can ask em for help. Their axles work great, no need to do anything other than install them.
Janos
Old Jun 14, 2008 | 04:35 AM
BoRiCuA's Avatar
Default Re: HELP NEEDED WITH 91 CRX SI B-SERIES SWAP (Janos Lin)
ok so if i have a 93 gsr block and the half shaft came with it, but i have a b16 ys1 cable trans I need to get 90-93 integra axles?
What about the spindles will the axles fit if i took off the dust shield?
Old Jun 14, 2008 | 05:03 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Janos Lin &raquo;</TD></TR><TR><TD CLASS="quote">The half shaft will go in any cable or hydro transmission. Only difference is with 92 or 93+ trannys, u need to use a different driver's side oil seal to accomodate the difference in the seal diameter. In other words, use the seal that goes with the half shaft.
Janos</TD></TR></TABLE>
x 2, I love my raxles, and since buying them have had 3 of my friends purchase sets of axles from them.
Old Jun 14, 2008 | 08:13 AM
jlicrx's Avatar
http://www.hasport.com/news/ar...2.htm
Old Jun 14, 2008 | 11:35 AM
JDM_DC4_Fanatic's Avatar
Default Re: HELP NEEDED WITH 91 CRX SI B-SERIES SWAP (jlicrx)
I have a 91 CX civic with B16a with cable ys1. I am using 91 DA non abs axels. The only mod you need to do is pry out the inner dust sheild from the back of the knuckel, unless you are already using Si knuckels.
Old Jun 14, 2008 | 11:49 AM
BoRiCuA's Avatar
Default Re: HELP NEEDED WITH 91 CRX SI B-SERIES SWAP (JDM_DC4_Fanatic)
I will get 90-93 teg axles correct? axles from raxles!! Yes my crx is a 91 si, so will i have to remove the inner shield?
Old Jun 15, 2008 | 05:14 PM
BoRiCuA's Avatar
what about the seals?
Old Jun 16, 2008 | 12:05 PM
BoRiCuA's Avatar
so what kind of axles if i have a 91 si, and the dust shield?
Old Jun 16, 2008 | 01:34 PM
ComeOnKip's Avatar
call and ask for marty at raxles... he'll guide you through what you need to know.
Old Jun 20, 2008 | 06:19 AM
Default Re: (ComeOnKip)
91 integra axels, non abs.
If you install it, and tighten the axel nut and try to turn the hub and its very hard, then you need to remove the inner dust sheild. If it turns freely, then your good to go
lsvtec_hatchback
Nov 5, 2015 08:21 AM
Shonda
Oct 18, 2006 07:57 AM
GSRCRXsi
Dec 10, 2004 08:13 PM
turbox
Dec 3, 2004 04:55 PM
gatesrex91
Dec 17, 2003 08:52 AM
