Bottom fuel filter line nut stripped
Old Jun 12, 2008 | 04:30 PM
LyghtFunky1's Avatar
Default Bottom fuel filter line nut stripped
Yeah, so after everything I've done, I can't seem to replace a damn fuel filter on a 97 DX with a line wrench, the 14mm bottom line nut stripped on me, no matter what I tryed
Thus, what are my options now?
Thanks
Old Jun 12, 2008 | 04:31 PM
#14 on this picture is what stripped out on me.
Old Jun 12, 2008 | 04:34 PM
bobjohnson's Avatar
Default Re: (LyghtFunky1)
Hows it stipped? The ridges on the bolt are stripped, or the threads are stripped?
Either way, vice grips.
Old Jun 12, 2008 | 04:36 PM
pdiggitydogg's Avatar
Rounded off, Im guessing.
Vice grips. Problem solved
Old Jun 12, 2008 | 04:47 PM
vice grips continue to strip it even more, and yes its rounded off.
Old Jun 12, 2008 | 04:59 PM
Then make them tighter........."youre doing it wrong"
Are you using pliers that have rounded jaws or flat?
Did you use any PB Blaster ahead of time?
Edit***
Wait, this is going to be a dumb question, but you cant put dumb past anyone.
You are turning it the correct direction, arent you? Its upside down...
Old Jun 12, 2008 | 05:00 PM
Flat
Old Jun 12, 2008 | 05:02 PM
Go get these:
http://www.sears.com/shc/s/p_1...0003a
Old Jun 12, 2008 | 05:43 PM
gsxr1k05's Avatar
i had the same problem. i just cut the bitch and got me a 1.99 inline filter from advanced auto and some fuel hose and hose clamps.
Old Jun 12, 2008 | 05:51 PM
o2flow.net's Avatar
Default Re: (gsxr1k05)
how bout you buy vise grips and line wrenches, the latter being what you should have bought before you started
EDIT: oh you did. ViseGrips FTW
Old Jun 12, 2008 | 05:53 PM
Default Re: (o2flow.net)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o2flow.net &raquo;</TD></TR><TR><TD CLASS="quote">how bout you buy vise grips and line wrenches, the latter being what you should have bought before you started</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LyghtFunky1 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, so after everything I've done, I can't seem to replace a damn fuel filter on a 97 DX with a line wrench...</TD></TR></TABLE>
I havent gotten to use this in awhile. Thanks Mister Zoolander's Mugatu avatar
Old Jun 12, 2008 | 08:18 PM
SarahVTEC's Avatar
Default Re: Bottom fuel filter line nut stripped (LyghtFunky1)
That sucks! I just replaced my fuel filter and that bottom nut is a PITA. I used some WD-40 and 2 open-end wrenches to break the filter and nut apart as shown below. However, mine wasn't stripped.
Modified by SarahVTEC at 9:25 PM 6/12/2008
Old Jun 13, 2008 | 02:44 PM
Okay, after 2 days & 3 people, this nut refuses to come off.
What are my options? I considered cutting the line & using a flaring tool, any ideas?
Old Jun 13, 2008 | 03:05 PM
I seriously cannot understand what has gone so wrong here.
Either way, if you feel that youve reached the end of your options, yes, you can cut the line (USE A PIPE CUTTER! NOT A GRINDING WHEEL).
The fitting is m10, I believe, which is the same as those for the stock brake lines (you can buy a hardline with fittings, from the parts store, cheaply.
Double flare the end.
Before you do this, however, I cannot stress how important it is that you make sure you have enough slack in the line to do this. You will lose at least 1" of the line, so be sure you have 2" minimum of slack. To verify, just leave the line attached, and undo the 3 nuts securing the filter to the firewall.
Old Jun 13, 2008 | 03:09 PM
What has gone wrong is the nut will not [freak]ing move.
It was moving slightly for about 2 turns, then it completely stopped. I myself am amazed at what this has turned into, but it has.
Wrona
10
Mar 30, 2011 09:56 PM
MelJ
10
Mar 20, 2011 05:26 PM
clemsonteg
Jun 13, 2006 06:09 PM
nk2k2
Oct 25, 2005 12:03 PM
AK94GSR
Aug 7, 2002 08:02 PM
