explain/translate/help
Old Jun 12, 2008 | 11:11 AM
Pleiadi79's Avatar
Default explain/translate/help
Hi guys,
i'm searching over the e-shop a drag crankshaft for my b16a2 but i wasnt able to find the correct translation of theese words. is There someone that could techinccally explain to me the meaning.
journal bearing, journal width, rod journal ?
Do someone is using a lighweight crank from eagle?
Wich one cams for drag racing?
thk
Old Jun 12, 2008 | 04:06 PM
1992Si's Avatar
I would suggest you go to the drag racing forum and contact Joe Simpson (Turbo-charged) or Jeff@Tempest they're easy to find there.
PM them for help. They can get you anything you need.
You can tell them I sent you. They'll take care of you.
Bearing journal; is the area in the block or connecting rod where the bearing sits.
here;
http://www.acuraautomotivepart...ormal
Modified by 1992Si at 8:12 PM 6/12/2008
Old Jun 13, 2008 | 04:09 AM
Pleiadi79's Avatar
Thanks a lot you are helpful
Ciao
pumafeet10
Jan 7, 2009 08:34 AM
aldong
Apr 27, 2005 10:29 PM
tek_civic
Jul 11, 2003 10:41 PM
ill_take_one
Feb 22, 2003 07:40 AM
gsrvx
May 22, 2002 09:16 PM
