Help With 93 Civic Ex. Clutch Not Working. Goes all the way to floor, stuck in first gear.
Old Jun 12, 2008 | 09:46 AM
bruderhood15's Avatar
Default Help With 93 Civic Ex. Clutch Not Working. Goes all the way to floor, stuck in first gear.
And at this point I cant drive it to a mechanic, whats there to do?
And I have a hydraulic clutch if that makes a difference
Old Jun 12, 2008 | 09:52 AM
Default Re: Help With 93 Civic Ex. Clutch Not Working. Goes all the way to floor, stuck in first gear. (bru
bump?
Old Jun 12, 2008 | 09:58 AM
xlasianizelx's Avatar
what do u mean by stuck in first gear, are there any clutch fluid in the resivor?,
Old Jun 12, 2008 | 10:09 AM
Default Re: (xlasianizelx)
Like my clutch isnt working at all, so im not able to shift gears at all
Old Jun 12, 2008 | 10:14 AM
BlackoutVTi's Avatar
Default Re: (bruderhood15)
Check shift linkage for any bends or breaks. Check master and slave cylinders for malfunctions and leaks. Check your clutch lines for bubbles and leaks.
Old Jun 12, 2008 | 12:02 PM
Default Re: (BlackoutVTi)
Thanks I will try! Appreciate it so much!
Old Jun 12, 2008 | 12:09 PM
champneys05's Avatar
you need to drain your clurtch of fluids and put brake fluid back into it!
Old Jun 12, 2008 | 05:09 PM
Default Re: (champneys05)
Worked thanks buddy! What do you drive, your in jack too?
dohctor_B
Transmission & Drivetrain
Sep 4, 2012 06:31 AM
lxdriver
Feb 26, 2011 07:28 PM
jwshilli
Jul 14, 2009 03:02 PM
HokieinCville
Feb 15, 2007 11:46 AM
Jedi_Sol
Apr 13, 2003 11:41 PM
