cluster, tailight and side marker issue
Old Jun 11, 2008 | 02:13 PM
EcivicG's Avatar
Default cluster, tailight and side marker issue
i drive a 93 ej2 or civic dx
so i was told i could wire my side markers to be on with my corner lights and also blink when signaling. so i wired the side markers to the corners like this
black to the ground wire, red to the power and also green wire. which i guess is a no no. before i had it just wired up to the red power wire and just always on..
so i did that then tried to turn on my lights and heard a pop or two.
right now my cluster doesn't work or light up. no speedo, fuel, or heat temp guage works, i can't signal, my corners domn't light up and my tailights don't work.
i looked for some of the fuses under the dash but i don't have a cover and don't know what fuses go to what. and help? thanks
Old Jun 11, 2008 | 02:25 PM
BlackoutVTi's Avatar
Default Re: cluster, tailight and side marker issue (EcivicG)
Definitely some fuses popped. I don't have my hayne's with me, but I'll take a look around for you.
In the meantime, you can see if you can find the fuses that are burned out.
EDIT: I win, found it for you. Here's a page from the FAQ's with diagrams for our under dash fuse boxes.
https://honda-tech.com/zerothread?id=1966666
EDIT EDIT: Take a look down the page under the 1992-95 civics. #15 and #19 especially look interesting
Modified by BlackoutVTi at 3:36 PM 6/11/2008
Old Jun 11, 2008 | 02:55 PM
EcivicG's Avatar
Default Re: cluster, tailight and side marker issue (BlackoutVTi)
thanks a lot. it'll save me some tickets and going to jail for tailights being out at night.
Old Jun 11, 2008 | 02:58 PM
No problem, I've got nothing to do while I'm waiting on an answer to my thread anywho.
Old Jun 11, 2008 | 03:28 PM
EcivicG's Avatar
well went out into my 110 degree heat to climb under my dash and turns out that my 15 and 19 fuses are blown!
go figure
but my 19 had a 20 amp fuse and on the diagram it says 10a.
so should i go out and buy a 10 for it?
stupid question what happens if you use a different ampere rating for a fuse?
Old Jun 11, 2008 | 03:47 PM
Haha, what are the odds?
Anywho, apparently someone did some improper work. Specific fuses are in specific places in order to keep your wires from melting and frying. Then you'll really have a mess. Let's hope that didn't happen before the fuses popped.
Now that you've come across said improper fuse, I say yes, do go get a 10 for it so you're not risking electrical problems down the road.
PS- make sure you disconnected the wiring that was the cause of the short. I burned out a brand new replacement fuse once because I was hot and wasn't thinking things through.
Old Jun 11, 2008 | 03:54 PM
EcivicG's Avatar
edit-------
so i bought the two 10 amp fuses i needed for 15 and 19, which got my speedometer, turn signals, fuel guage, temp guage back and working but right now i can't tell if the lighting for the guage cluster are working, and my parking lights for the corners, and tails still aren't working.
any other input? thanks
Modified by EcivicG at 7:13 PM 6/11/2008
Modified by EcivicG at 7:14 PM 6/11/2008
Old Jun 11, 2008 | 06:15 PM
EcivicG's Avatar
^^top
trying to get this fixed before i have to go across town to work.
Old Jun 11, 2008 | 10:21 PM
EcivicG's Avatar
the guage cluster lighting and parking lights are the only things that aren't working now, but i can't seem to figure it out. none of the bulbs are burned out, all the fuses underneat the driver dash are good.
anyone have any ideas?
Old Jun 12, 2008 | 08:54 AM
You may now have to check your wiring. However unfortunate, it's possible that because of that jacked 20 amp fuse, your wiring has suffered from the short, and could have fried.
kwae
11
Feb 13, 2014 07:51 AM
JDMEMone
14
Jun 25, 2012 07:20 PM
93_FSWAP
Sep 8, 2011 12:56 PM
boost and bass
Dec 3, 2009 04:41 PM
dungsta
May 16, 2005 01:57 PM
