want to do a automatic to manual swap 92-95 hatch
Old Jun 11, 2008 | 10:57 AM
slammedstd's Avatar
Default want to do a automatic to manual swap 92-95 hatch
I'v never done it before just wondering if i will run into any problems with starting the engine i'm puting a z6 in it any suggestions would really help thanks
Old Jun 11, 2008 | 11:17 AM
vtecb18c's Avatar
Default Re: want to do a automatic to manual swap 92-95 hatch (slammedstd)
you should have no problems starting the car if you have a mt ecu...you did make sure you got the clutch petal, shift lingage, ect... right?
Old Jun 11, 2008 | 11:27 AM
slammedstd's Avatar
Default Re: want to do a automatic to manual swap 92-95 hatch (vtecb18c)
yeah i have everything to do the swap what about the atomatic park lock to start the car
Old Jun 11, 2008 | 11:48 AM
vtecb18c's Avatar
once you install the ecu and everything there wont be a lock..thats why you need a manual ecu not an suto for that reason and others like overdrive
Old Jun 11, 2008 | 11:57 AM
slammedstd's Avatar
ok cool thanks for the advice man
Old Jun 11, 2008 | 12:06 PM
vtecb18c's Avatar
no prob
Old Jun 11, 2008 | 12:16 PM
slammedstd's Avatar
should i buy the hasport tranny mount or do something else
Old Jun 11, 2008 | 01:41 PM
vtecb18c's Avatar
you should be able to use the si tranny mount but im not sure someone else will probally chime in with more info
Mandark06
Feb 24, 2007 08:28 PM
srg
Aug 16, 2006 10:37 AM
wannab20hatch
Aug 21, 2002 07:03 PM
LS Teg
Mar 21, 2002 02:47 PM
