95 civic rhd swap
first off i got a 95' honda civic ex coupe and im wantin to swap it to rhd. i want to put the gsr dash in it and then eventually a gsr motor swap but that not what im want to ask about.
k im pretty sure i know the basic stuff to get for the swap but just on the safe side i need to know everything i need. i know i need the clip, wiring harness and a couple of other things. anything else you guys can tell me i have to have let me know. so i would appreciate it if you guys would tell me and dont leave a single item out cause i want it to be done right. also i dont need to know how to do it i just need the items that i need to do it. but ill take advice about it to make thanks easier.
thanks
Modified by jesstopher2nr at 11:49 AM 6/11/2008
thanks
you should have everything you need when you receive your clip...it should have the harness when you get it...its not an easy job for someone who hasnt done extensive mechanical work....be sure you know what your getting yourself into, grab some manuals and have at it...good luck
man i apperciate ur advice. and i was basicly lookin for a item/parts list and i believe everything does come with it, but i was wantin to know if thats everything i need. someone i know told me that ill be lookin at a grand for what i need and thats including the rh gsr dash. so what do you think. and btw im not gonna be doin this all by myself.
Juk3zz
Oct 7, 2010 06:27 PM
01typer1124
Oct 29, 2005 09:15 PM
