HELLLPP!!! Honda CIvic Fuel Pump junk
Old Jun 10, 2008 | 09:48 PM
4doorcivic9's Avatar
Default HELLLPP!!! Honda CIvic Fuel Pump junk
So, for some reason I go to start my car and it won't start.
Well First things first I Checked the sparkplugs, their good to go..even changed them and gapped them right.
Then I listened and noticed my fuel pump wasn't kicking on like it should. I have a walbro 255..and for ppl that have them know that their loud. So, I took it apart, put the fuel pump on my other car...works perfect. Then I put a stock fuel pump on the car and it still wouldn't start, then put that fuel pump on my other car and it worked perfect as well.
Checked the fuel regulator to the fuel line and of course its not getting any gas b/c of the pump not doing its job, but its long clogged or anything.
I do have pressure gauge on my fuel filter and it usually always reads 45psi and well it doesn't read anything. I can't figure out what is wrong. Please help me with this
Old Jun 10, 2008 | 10:38 PM
never mind, i THINK it might be my main relay.
Old Jun 10, 2008 | 10:49 PM
ok well jk again. Im hearing a clicking noise from my fuel line to my fuel rail and its the main relay so that is working properly as well. If its not the main relay and its not the fuel pump...WHAT IS IT!??! HELPP!
Old Jun 11, 2008 | 06:18 AM
bump..still need help or any solutions to be able to look at?!?
Old Jun 11, 2008 | 06:31 AM
BlackDeuceCoupe's Avatar
HT White Ops
Default Re: (4doorcivic9)
What I do in situations like this is....
Squirt a bunch of WD-40 down the throttle body (WD-40 is flammable amongst other things) and crank the engine.
If it starts momentarily, revs n' dies, then its a fuel problem!
If it doesn't fire - just cranks - then its an electrical problem!
Give this a try and go from there...
pappasmurf
Nov 11, 2024 07:43 AM
nicko360
15
Jan 17, 2007 06:22 PM
Cameron60
Jan 16, 2007 06:04 PM
whitehf
Aug 6, 2006 01:22 PM
crazygerman
Mar 4, 2006 11:57 AM
