Help Changing a fuel pump
* B A N N E D *
Help Changing a fuel pump!!!!!!!!!!
I am pretty sure I need a new fuel pump in my eg, is it still possible to start a car without a fuel pump, b/c mine starts, but then dies...
How hard is it to change a fuel pump, are there any lines that need to be blocked off?
Thanks
Thanks
* B A N N E D *
Re: Help Changing a fuel pump!!!!!!!!!! (Throwdown)
i've tried changing my fuel pressure regulator and fuel filter already,
the fuel pump sounds different when i turn the car on
* B A N N E D *
Re: Help Changing a fuel pump!!!!!!!!!! (nicko360)
i can hear the fuel pump turn on but it sounds different
the car starts but bogs out after a couple secs
* B A N N E D *
the car bogs then shuts off
the only way I can keep it alive is by tapping the gas, consistant pressure cuts it off
Location: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
1 Post
ok...well when it shuts off does it start RIGHT back up? or you have to wait ? this could be a few things i'm just tring to narrow them down
* B A N N E D *
the next few times it doesn't start up, but then it will start up again after a few trys
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Throwdown »</TD></TR><TR><TD CLASS="quote">ok...well when it shuts off does it start RIGHT back up? or you have to wait ? this could be a few things i'm just tring to narrow them down</TD></TR></TABLE> ok when it does this you should check for fuel and spark then ....go from there
take out back seats, you will see the cover take the screws out disconnect the wiring and pull it out. connect the new one, put it in, put screws back in and put ur seats back in
1 Post
Re: (wip_customs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Throwdown »</TD></TR><TR><TD CLASS="quote">you may want to look more into this instead of assuming its the fuel pump and wasting money</TD></TR></TABLE>
4doorcivic9
06-11-2008 06:31 AM
iNDyCRX
04-24-2008 12:54 PM
Cameron60
01-16-2007 06:04 PM
