integra brakes on an eg......how easy is it? please help
Old Jun 10, 2008 | 09:06 PM
bokeyboone's Avatar
Default integra brakes on an eg......how easy is it? please help
i have a 95 dx hatch....i want to swap in f/r disks from a gsr or type r. i just need to know exactly what i need to do the Easier swap of the 2 above. thanks in advance!
Old Jun 10, 2008 | 09:09 PM
BlueIntegraBoy's Avatar
Default Re: integra brakes on an eg......how easy is it? please help (bokeyboone)
Obtain full knuckle assemblies and trailing arm assemblies. Unbolt old stuff, bolt in new stuff. Bleed brakes. Real easy.
Old Jun 10, 2008 | 09:41 PM
95vxtealhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bokeyboone &raquo;</TD></TR><TR><TD CLASS="quote">i have a 95 dx hatch....i want to swap in f/r disks from a gsr or type r. i just need to know exactly what i need to do the Easier swap of the 2 above. thanks in advance! </TD></TR></TABLE>
You want any integra brakes, gs, ls, and gsr, those would be the less costly of the two. Its swap is easy you need integra spindles, and a 91 civic sedan master cylinder to cope with the bigger caliper fluid displacement. I suggest you get new wheel bearings, inspect both ball joints, and install new out tie rods because your down there anyways. Make sure you check your caliper dust seals, and lube up the pins your calipers slide on. I really suggest you replace all your lower control arm bushings, and both radous arm bushings when you do all this.
Modified by 95vxtealhatch at 11:13 PM 6/10/2008
Old Jun 10, 2008 | 09:54 PM
bsmith100's Avatar
Default Re: integra brakes on an eg......how easy is it? please help (95vxtealhatch)
From what I have been told the GSR brakes will bolt on.
The type R brakes will require a little modification.
Old Jun 10, 2008 | 10:08 PM
bokeyboone's Avatar
Default Re: integra brakes on an eg......how easy is it? please help (bsmith100)
which ones would b easier? gsr or type r
Old Jun 10, 2008 | 10:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bokeyboone &raquo;</TD></TR><TR><TD CLASS="quote">which ones would b easier? gsr or type r</TD></TR></TABLE>
Read the first line of my last post.
Old Jun 10, 2008 | 10:13 PM
bokeyboone's Avatar
do u mean non-gsr/type r integra brakes?
Old Jun 10, 2008 | 10:17 PM
bokeyboone's Avatar
never mind he last post i see it now. that answers my question perfectly. thank you
Old Jun 11, 2008 | 11:07 PM
bsmith100's Avatar
I think he meant brakes from the regular (not the Type R) versions.
97civic94gsxr
Aug 1, 2008 07:57 AM
NipponRacing
Mar 22, 2004 12:09 PM
Comfortable Rock
Jul 16, 2003 11:26 AM
Yellow Dragon
Apr 16, 2002 09:18 PM
B_CRUZ!
Nov 23, 2001 07:04 PM
