Big Problem: After ABS delete
Ok I removed the ABS out of my car. It didnt work, and did an annoying noise. I took everything out. Front line abs unit. I put in a prop valve with rs lines the whole deal. I got a small leak on one of the lines.
1. How Can I fix the small leak?
2. When I press the brake the car idles like if Im revving it. So what the hell?
Today, I turned on the car, turned it off, and then later I tried turning it on and I pressed the brake and the power cut off completely.
3. What can I do, Ive been working on this since Saturday, and Im pretty fustrated?
Ive checked everything and checked connections fuses, the whole deal. I dont know what else to do.
