quick help! ABS problem
Old Jan 9, 2004 | 10:12 AM
EF8 JUNKIE9's Avatar
Default quick help! ABS problem
ok everytime i start my car theres a buzzing sound the goes on for like a minute and its goin on on my ABS and then when it stops ABS light goes on i checked if abs works and it does work dont knoe what the problem may be anyone might knoe what the problem is?
Old Jan 9, 2004 | 10:49 AM
Caffeine Slug's Avatar
Default Re: quick help! ABS problem (daymthatgsr12)
Check your ABS reservoir, it's probably out of brake fluid. Fill it up and it should go away, if that's the case.
Old Jan 9, 2004 | 11:19 AM
mickey513's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daymthatgsr12 &raquo;</TD></TR><TR><TD CLASS="quote">ok everytime i start my car theres a buzzing sound the goes on for like a minute and its goin on on my ABS and then when it stops ABS light goes on i checked if abs works and it does work dont knoe what the problem may be anyone might knoe what the problem is?</TD></TR></TABLE>
Time to change the brake fluid in the abs. reservior
Samething happen to me. It's time to change the brake fluid in the ABS reservior. Very simple task. Flush it out and the noise will go away.
HTH
JDM_is_overrated
Sep 21, 2008 12:54 PM
jonzel
Jul 27, 2005 03:29 PM
seeeker
May 23, 2005 12:31 AM
PleaseHelp
Aug 16, 2004 07:45 PM
Audio28
Dec 22, 2002 11:48 PM
