Questions about the AEM EMS
Old Jun 10, 2008 | 02:30 PM
johnsc2235's Avatar
Default Questions about the AEM EMS
I have a 98 integra ls turbo, running the AEM EMS and the AEM wideband o2 sensor, t3 turbo, 550cc injectors, walbaro fuel pump, tial wastgate. Anyways I have a question for those that use this ECU. I am not at all impressed with it. I am having to problems with it and it has been tuned by shane at DB performance in rogers MN. Its making around 215 to the wheels which is ok for my daily driver and I m boosting about 10 psi. Anyways the problem I am having is two things. First and formost sometimes when I am driving and I push the clutch in to coast down to a stop or I am going around a cloverleaf on decel it will just quit. I lose all power and I have to restart the car or pop the clutch if I am going fast enough. It happens way to often and probably 5-10 times a day. And when I start the car it seems to crank for like 5-10 seconds before it actually starts. This is starting to **** me off. Also when I turn on the A/C it hesitates for a second or two and almost dies then the rpm's race to about 1500rpm and then back down. I am just about fed up with it. I am wondering if there is anything I can do or if there is a problem with the AEM or do I have to goto something like a hondata s300 to be more like stock? PLEASE HELP!!
Old Jun 10, 2008 | 03:02 PM
cluelessmale's Avatar
Default Re: Questions about the AEM EMS (johnsc2235)
need a EPM or Cam Tigger
Old Jun 10, 2008 | 04:12 PM
blinx9900's Avatar
Default Re: Questions about the AEM EMS (cluelessmale)
its all in the tune, i have aem ems, i used to have those problems cause we never tuned for driveability, once we did they all went away, there is a comp table to keep the car idling when the ac comes on or the stereo is bumped, your tuner may not be aware of that but it helps alot!! there are alot of start up tables that the tuner needs to play with. dont blame the hardware/software.
Old Jun 10, 2008 | 04:47 PM
DaveF's Avatar
probably getting alot of ign errors at low engine rpms, then it will stall out
perhaps this needs some attention on the ac situation
Old Jun 10, 2008 | 04:57 PM
johnsc2235's Avatar
Where can iget those and where do I install them? Do I have to get a re tune then? The tuner said he played with the start up maps and the maps for the a/c load. Any other ideas?
Old Jun 10, 2008 | 04:59 PM
DaveF's Avatar
http://www.t1racedevelopment.com (T1 cam trigger kit)
http://www.aempower.com (EPM)
try contacting HT user "whoally" . he may be able to help figure out your problem.
johnsc2235
Engine Management and Tuning
Apr 29, 2010 06:53 AM
johnsc2235
Jun 18, 2008 07:09 PM
sportridermike
Honda S2000
May 26, 2005 02:56 PM
ITRSpeed
Mar 15, 2004 07:43 PM
philo
Mar 11, 2002 09:23 AM
