Dohc ZC turbo
Dohc ZC turbo
Hey guys I'm in the process of rebuilding my Dohc ZC. I have purchased new stock P27 pistons and was planning on reusing the stock rods and boosting it. Do you think that I would be safe running the stock rods. Psi will be between 6-8. I have read that stock D series rods can handle up to around 220hp before giving out. And I know that I will not be going over that but I thought I would get some other people opinions on this before I decide. Also do you think that the stock compression will be fine for a turbo setup.
Any help is greatly appreciated
yes, stock compression is fine for a sub 200hp zc.
if you go any lower you will lose all your bottom end.
if anything i would go higher compression.
my stock zc did 170whp and 140wtq at the dyno with no tune. but i would say stay below 200whp on stock stuff.
Re: (jdm_dc_fan)
Why not just build the bottom end?
Then you can beat the **** out of it, and not worry about the rods failing.
I'm getting set to do an Obd-1 Dohc Zc with eagle rods (haven't decided on pistons) I'm hoping for around 300 whp at around 15psi.
Re: Dohc ZC turbo (89civichb)
I just sold my engine, I was runing a t25 (12psi)turbo zdyne and dsm 450 injectors. It was fun to drive with the t25 instant boost was quick great in the city.
Re: (jdm_dc_fan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_dc_fan »</TD></TR><TR><TD CLASS="quote">
stock internals dohc zc</TD></TR></TABLE>
damn them are good numbers for a stock bottom end!what was the set-up on that motor?
Modified by zccr-xsi at 12:17 PM 2/1/2008
Re: (89civichb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">yes, stock compression is fine for a sub 200hp zc.
my stock zc did 170whp and 140wtq at the dyno with no tune. but i would say stay below 200whp on stock stuff.</TD></TR></TABLE>
haha! dude, just no...
stock zc can easily push 15 lbs with the right tune, stock internals and all..
and to answer all your questions even a 99' y7 internals can hold up 11psi on a stock block with a good tune.. i know because thats what i had before my zc.. all i have is dsm 450cc, walboro 255lph, and a phearable.net ecu tuned with crome
(stock map will not hold over 11psi)
an previously in my crx with the dual cam zc i was on 9psi running 211.7hp, 173. trq at 6400rpms with a full tune running a constant 11.4 a/f
word
word
Grandhustleman86
16
01-13-2007 09:12 PM
El pimp chulo
09-27-2006 09:58 AM
ZCREX
11-21-2001 01:33 PM
