bleeding the coolant system
Old Jun 10, 2008 | 06:36 AM
corince06's Avatar
Default bleeding the coolant system
i have a 92 civic si thats overheating and i was told to bleed the cooling system...i was wondering if anyone could tell me how to bleed the cooling system cause i have no clue...thank you
Old Jun 10, 2008 | 06:44 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: bleeding the coolant system (corince06)
1) Make sure car is completely cold
2) Fill radiator + overfill tank (to proper max) with coolant
3) Leave radiator cap off
4) Turn your heat on hot/defroster/on full blast and start your car
5) Allow air to bubble out of the radiator
6) As the level of coolant goes down, fill up with coolant.
7) Continue doing Step 7 until the heat coming out is hot/thermostat gauge is at normal operating temperature.
Old Jun 10, 2008 | 06:08 PM
corince06's Avatar
Default Re: bleeding the coolant system (SkoundrelUSA)
thanks a lot man
Old Jun 10, 2008 | 06:35 PM
ke98248's Avatar
Feel free to squeeze the coolant hoses gently to knead out any air bubbles also.. That has proved to work well in addition to the above.
Old Jun 11, 2008 | 12:48 PM
corince06's Avatar
Default Re: bleeding the coolant system (ke98248)
kk ill make sure that do that...thanks for the advice man
Empyre JDM
May 11, 2010 12:51 PM
B18c1vicrx
May 13, 2009 01:01 PM
dhn
23
Jan 5, 2008 01:06 AM
CDtegGo
Aug 27, 2006 02:22 PM
drumsy
Sep 12, 2002 07:14 AM
