loud pulsating humming noise from front end
99 pulsating humming noise from front end on speeds of 15mph and up, turning in either direction will still humm and moving foward always to. noise also gets louder when i go faster. so i thought it was chopped tires so i got brand new khumo tires and still nothing. so what im trying see is if there is a way to tell whether its the brakes or w. bearings?
check your brake rotors see if they're scored, check the heat sheilds on your front brakes maybe they're hitting the rotors. check the hub by whiggling your wheel vertically in and out and see if there's play... if there's play then it's a bad hub..
ill try this<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b1u3_5i »</TD></TR><TR><TD CLASS="quote">check your brake rotors see if they're scored, check the heat sheilds on your front brakes maybe they're hitting the rotors. check the hub by whiggling your wheel vertically in and out and see if there's play... if there's play then it's a bad hub..</TD></TR></TABLE>
pluckman4
May 12, 2013 01:47 PM
Origin
Aug 29, 2004 10:16 PM
