b16a1 8.0 comp 354whp
hello. here is my dyno from a super low comp b16a1, i bought wrong pistons and decided to run them anyway
it is wiseco b18c pistons, in a comp-calculator it gave me a comp between 7,8 to 8,0
here is the setup
B16a1 81,5mm wiseco b18c pistons 7,8-8,0 comp, eagle rods, ITR cams
home made ramhorn, garrett 57trim t04e 60/63A/R
3"downpipe and exhaust, 38mm closed loop wastegate
2,5" intercooler piping, backdoor intercooler
stock head, intake manifold and block
dynoed on a rototest 354WHP 1,6 bar dropping off to 1,3 bar
i stopped at that level because its maybe can last longer
its insane
here is the setup
its insane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike »</TD></TR><TR><TD CLASS="quote">get it to maintain boost up top and you'll probably see a good bit more power. with 8:1 compression, I'd crank the boost up.</TD></TR></TABLE>
He's at over 1.6bar = 22psi. As long as his map sensor can go over 28, he can do so, but because he's at such a low compression, it takes more boost to get the same power. There's also a bit of off-boost response that is sacrificed, also. Glad you're happy with it..
put some cams in that thing and it will make a big difference.
my buddys car has basicly the same setup, his made 390 on 14lbs, 480 on 18lbs all on pump gas. he has CTR cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">put some cams in that thing and it will make a big difference.
my buddys car has basicly the same setup, his made 390 on 14lbs, 480 on 18lbs all on pump gas. he has CTR cams</TD></TR></TABLE>
it says he has itr cams, i doubt their would be any difference with ctr
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EARLdaSQUIRREL »</TD></TR><TR><TD CLASS="quote">
it says he has itr cams, i doubt their would be any difference with ctr</TD></TR></TABLE>
hmm i thought i read stock head... oops
Jason Helton
Mar 12, 2018 06:34 PM
