can i use same camshafts for d15b and d16z6
Old Jun 8, 2008 | 09:09 AM
josh tavares's Avatar
New User
Default can i use same camshafts for d15b and d16z6
please help some one gave me a camshaft for d16z6 but im not sure if it can fit my d15b engine
Old Jun 8, 2008 | 09:19 AM
wmac's Avatar
if its a d15b vtec, yes
Old Jun 8, 2008 | 09:27 AM
elektronsi's Avatar
Default Re: (wmac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wmac &raquo;</TD></TR><TR><TD CLASS="quote">if its a d15b vtec, yes</TD></TR></TABLE>
Old Jun 8, 2008 | 07:04 PM
New User
Default Re: (elektronsi)
my engine block has compresion of 12.2 is ok if i put a turbo kit in it?? is it safe?
coz my friend said that its not....
Old Jun 9, 2008 | 05:10 AM
yozsi's Avatar
my cummins runs 19:1 compression and 45 psi..... so i'd say you can run a turbo on that compression. Lots of tuning, lots of fuel, low boost, high octane...
Old Jun 9, 2008 | 08:43 AM
turbojdmhatch's Avatar
Default Re: (yozsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yozsi &raquo;</TD></TR><TR><TD CLASS="quote">my cummins runs 19:1 compression and 45 psi..... so i'd say you can run a turbo on that compression. Lots of tuning, lots of fuel, low boost, high octane...</TD></TR></TABLE>
its also i diesel......if ur running a 12.2:1 u would have to run 100 octane all the time do u even know how to acheive that high of compression or does the person that said that even know?
Old Jun 9, 2008 | 11:08 AM
delsolsteve's Avatar
Default Re: (turbojdmhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">my cummins runs 19:1 compression and 45 psi..... so i'd say you can run a turbo on that compression. Lots of tuning, lots of fuel, low boost, high octane...</TD></TR></TABLE>
i think he means 9:1 compression ratio, anything over 10:1 for honda motors would be retarted to boost, example the k20, 11.5:1, i haven't seen anyone boost it, and if they have, i garuntee thats some low boost, under 8psi, your already on high compression
high compressions + boost = good bye motor.
Old Jun 9, 2008 | 07:57 PM
Default Re: (delsolsteve)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsolsteve &raquo;</TD></TR><TR><TD CLASS="quote">
high compressions + boost = good bye motor.</TD></TR></TABLE>
look up cheesefrog's hatch on youtube and theres a video of him getting a tune/dyno run in thats a stock k20. dont tell people bad info(saying this nicely) anyone can turbo a higher compression motor the tune is where not blowing the motor up comes from
and no he doesnt mean 9:1 compression ratio. the compression ratio of a diesel motor is a lot higher than ours BTW
Old Jun 13, 2008 | 07:40 PM
New User
will a stage 3 crower cams fit my engine coz i changed its pistons thankyou guys
Old Jun 13, 2008 | 09:17 PM
wmac's Avatar
high lift cams with high compression pistons should be 'clayed' for clearance.
also its possible the valve reliefs are not big enough or in the wrong place.
Old Jun 13, 2008 | 10:59 PM
obuhmyuh's Avatar
Default Re: (josh tavares)
sounds like you need to do a lot of research, instead of asking all of the questions in one thread. the z6 cam will fit in a d15b, but from what im told the d15b's camshaft is slightly more aggresive, so swapping them would be pointless.
i have a d15b and im actually running a z6 shaft cuz i fukced my d15b's up a little last time it was out, untill i can get my crower cam in my head this weekend
Old Jun 13, 2008 | 11:35 PM
Syndacate's Avatar
Default Re: (wmac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wmac &raquo;</TD></TR><TR><TD CLASS="quote">high lift cams with high compression pistons should be 'clayed' for clearance.
also its possible the valve reliefs are not big enough or in the wrong place.</TD></TR></TABLE>
Yeah, that would be the main problem area.
I mean yeah, you'll be shooting stupid high compression numbers for a daily driver, and will probably need to run 100 octane fuel every day (which is perfect for ya if you consider the way gas prices are ) - though that's not even the real beef. The main problem comes into effect as wmac said, with a longer lift duration of a more aggressive camshaft the valves are going to stay out longer - which on a stock motor is fine - though you probably have longer rods and/or higher compression pistons to achieve your already higher compression, which might create clearance issues.
In short, you'll either have to A) Take some measurements and do some calculations, B) Take it to a machine shop, C) Plug it in and hope it doesn't pwn your valves, D) Take it to a machine shop, they can properly check it, D) find somebody with the same setup.
Old Jun 14, 2008 | 03:26 AM
itsmejto's Avatar
Default Re: (yozsi)
12.2:1 with a turbo, no wah jose , you'll send the cylinder head into orbit and your cranshaft to hell..
Old Jun 14, 2008 | 04:04 AM
Rok_Stok's Avatar
Default Re: (itsmejto)
The D15B's cam timing is 9° off of the D16Z6's. I can't remember is it's advanced or retarded.
scUba-stEve
Jul 2, 2005 08:02 PM
simplypinoyy
11
Mar 7, 2004 09:03 AM
dragteg
Oct 20, 2003 07:17 PM
Soon_2b_evil
Oct 9, 2003 06:25 AM
Btothe3rdDegree
10
Sep 7, 2003 05:29 PM
