head with APR head stud question.
Old Jun 6, 2008 | 03:56 PM
mehrshadvr4's Avatar
Default head with APR head stud question.
hi guys. this is my first time posting here. i'm building my frinds b18 for turbo and now i can't find any spec for APR studs. are the torque specs same as factory head bolts? i also need to know the way to tighten them up. i looked at aldata but couldn't find anything about it. i also would like to know how much power the stock non sleeved block can handle. thanks
Old Jun 7, 2008 | 08:58 AM
B18Ch1ck's Avatar
Default Re: head with APR head stud question. (mehrshadvr4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Originally posted by JustinKlemgold on Mar/27/08
With ARP, if you are turbo, take them to 80. One time use, however. But your HG won't leak.
http://www.team-integra.net/fo...35779
also B18 is too specific. you could be referring to something from from a 120 hp B18A to the JDM B18C Spec R...
Old Jun 7, 2008 | 02:02 PM
Thrizzle's Avatar
* B A N N E D *
ARP recommends 70 ft/lbs
I take it to 75 ft/lbs... on every motor I've built, seen over 700whp on them.. no problem.
Old Jun 7, 2008 | 08:04 PM
Default Re: head with APR head stud question. (B18Ch1ck)
it's b18 c spec R, but isn't 700hp out of stock cylinder a little too high? i heard close to 500 is the max before cranking the cylinder walls.
Modified by mehrshadvr4 at 9:10 PM 6/7/2008
918DA_6
Nov 3, 2008 05:14 AM
HamiltonRex
Apr 18, 2006 09:02 AM
Hatchamaback
14
Jul 28, 2005 10:12 AM
skunksol
15
Mar 28, 2004 11:41 AM
