Roof Panel
I was wondering if anyone knew the part number for the roof panel. I just picked up a type r shell that someone installed a sunroof in and i would like to remove it. Any help would be appreciated! thanks.
It looks ok....i suppose i just dont want a sun roof. I couldnt pass on the deal though it was too good. Its some after market one too. I need to pick up a new headliner and that roof panel.
but i have no idea why someone would do such a thing.
I would be willing to bet that you could remove the sun roof, weld in a few supports,and some new sheet metal, and it would be cheaper than buying a new roof skin....
but I could be wrong...
good luck on your project......
pics are mandatory of the process/progress
If it were me, I'd replace the roof skin instead of just welding the hole shut.
I don't know the part number, but http://estore.acura.com has it under the body/chassis section if you look up ITR parts.
I was also interested in learning more about this.
Understand Composite Fab made some CF roofs that were a complete replacement (not just cap) for the factory roof. Too bad they went out of business
Thats the picture that comes up, but its the correct part. If you could pull up the part number, it'd come up as a different number compared to the LS/GSR roof. I'm almost positive I had this looked up at Acura one day.
there is a person selling a composite fab cf headliner if you want it. i think hes asking 500 for it. http://www.hondamarketplace.co...96583
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 »</TD></TR><TR><TD CLASS="quote">I would be willing to bet that you could remove the sun roof, weld in a few supports,and some new sheet metal, and it would be cheaper than buying a new roof skin....
pics are mandatory of the process/progress </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eluam »</TD></TR><TR><TD CLASS="quote">If it were me, I'd replace the roof skin instead of just welding the hole shut.
hence the reason I said weld in support bars also....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR.#1446 »</TD></TR><TR><TD CLASS="quote">roof skin is alot easier and cleaner to do......my friend bought a itr that the owner also put a sun roof in
does your friend have any pictures of the process?
</TD></TR></TABLE>does your friend have any pictures of the process?
hence the reason I said weld in support bars also....</TD></TR></TABLE>
And I'd still say to replace the entire roof skin.
And I'd still say to replace the entire roof skin.</TD></TR></TABLE>
x2 there is already support beams across the roof why add more???
If you are going to be adding a CF roof might as well replace the steel roof as opposed to using a CF roof skin. Why would you want more weight up top? How much do those Cf roofs run?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RPM »</TD></TR><TR><TD CLASS="quote">If you are going to be adding a CF roof might as well replace the steel roof as opposed to using a CF roof skin. Why would you want more weight up top? How much do those Cf roofs run?</TD></TR></TABLE>
no one makes them right now
I have 5 sitting in my composites shop and am going to try to sell them soon and go into production.
I am working on structural ones as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Furley »</TD></TR><TR><TD CLASS="quote">Is the ITR roof skin same/diff size compared to the LS/GSR?</TD></TR></TABLE>
Same as the RS
Same as the RS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">
Same as the RS</TD></TR></TABLE>
But braces are stronger. I thought the skin was thicker too.
Do a new skin, its not too bad, I did it on my 93 hb. if you just patch it eventually the welds will show, if you buy a cf skin, it won't be oem. Being that it is an R, Go the cleanest nicest way.
Part number is: 62100-ST7-G00ZZ
Full retail in CAD is $806
and it's the cheapest roof panel for the Integra out there...the RS one is a different part number and retails for $884CAD.
good luck with your project.
i forget who quoted me once, but i almost ordered one for my R which has a sunroof for $371 or something
people act like a sunroof is completely unfixable
can be easily done for under $1000 no problem
Acura said its $649.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Same as the RS</TD></TR></TABLE>
So, thats a No.
So, thats a No.
Bryro22
Audio / Security / Video
May 13, 2004 04:15 PM
Charlie Moua
Mar 10, 2004 10:17 AM
90-CRXSi
22
Oct 22, 2002 11:03 PM
