Need help on adjusting valves..asap
Old Jun 6, 2008 | 11:23 AM
Mac101989's Avatar
Default Need help on adjusting valves..asap
my valves sound like their preety lous now, so i want to to a valve adjustment, but i dont know how much is needed to adjust it. here are some pics of my engine, and also theres a pic of the cam gear in this engine aswell.
Old Jun 6, 2008 | 11:42 AM
instructor74's Avatar
Default Re: Need help on adjusting valves..asap (Mac101989)
buy a good shop manual for the car it has step buy step instructions on how to do a valve adjustment. Look under the hood there will be sticker with the valve spec on it adjust each valve to spec using a feeler gauge. Doyour adjustments when the engine is cold, overnight cold is best.
Old Jun 6, 2008 | 12:01 PM
mohater's Avatar
Default Re: Need help on adjusting valves..asap (instructor74)
Check the FAQ page -
Here's the link from the FAQ page:
https://honda-tech.com/zerothread?id=1305086&page=1
Old Jun 6, 2008 | 02:40 PM
Mac101989's Avatar
Default Re: Need help on adjusting valves..asap (mohater)
umm this is a jdm engine, its not its stock one, and where can i buy a manual for this engine?
Old Jun 6, 2008 | 04:50 PM
mohater's Avatar
The only difference will be the gaps, that's the only thing you will need.
Have you taken the valve cover off to see if it is any different?
Old Jun 6, 2008 | 04:56 PM
SOHC_civic_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mac101989 &raquo;</TD></TR><TR><TD CLASS="quote">umm this is a jdm engine, its not its stock one, and where can i buy a manual for this engine?</TD></TR></TABLE>
LOL buddy that is a stock motor. what does the ZC come with 115 hp? Just research man the information is out there somewhere I promise you
Old Jun 7, 2008 | 05:03 PM
Mac101989's Avatar
Default Re: Need help on adjusting valves..asap (SOHC_civic_si)
anybody know any information on this engine about the size to adjusts the valves?or anything?
Old Jun 7, 2008 | 06:28 PM
HeikDiesel's Avatar
Specs should be about the same
manyakiexpi
May 22, 2006 07:48 PM
redpeppers
Jul 26, 2005 02:33 PM
RACEPAK
Jul 9, 2004 05:21 PM
zseeanz
Apr 7, 2004 03:16 PM
tjtruong
Oct 27, 2001 10:29 PM
